New ink - Probably 20 pages have been printed. Maintenance has been perfrmed. A test page prints correctly Sounds like it prints and paper feeds thru Hard wired connected to laptop, not wifi.
First step in this kind of issue is check the data cable is properly socketed.
Second step is perform a copy operation directly from the printer. If this fails your issue is printer or cartridge, so swap out the cartridge and retry. If still no copy - your printer has an electronics fault.
Step three is try a document ( D2) from a different application (App2). If it prints the new document (D2) - your issue is with the original document (D1) or the application (App1) printing from. Try printing a different document (D3) from the original application (App1). If document D3 prints from App1 - the fault is in the document D1, and if document D3 fails to print - the fault is in App1.
SOURCE: after replacing the black ink nothing prints
Hello, I am having the same problem and have done extensive research to find out that with this exact problem you have mentioned, you must clean the printer head, nozzles, and waste ink tube. the process is a bit long and needs patience. You will have to take the print head assembly out of the sliding caddle and put it in a glass of rubbing alcohol to disolve the dryed ink within the printer head assembly. it is held in with a silver metal plate that runs across the assembly and screws to the sliding carriage. be carefull to remove the black clip on the right of the carriage to take it out. note to be careful to not pull the white info lines of the head. leave it in the glass overnight and also clean the tube that runs under the waste pad station and clean the clear waste tube as well. ....Good luck
SOURCE: blank pages coming out of i850 with new printhead
Alarm / Power light flashes orange 7 times consecutively is a Print head error so it sounds like you did the right thing.
I would reseat the printhead along with each one of the ink cartridges. Make sure that you removed the tape from the bottom of each of the ink cartridges and try it again. After installing the new printhead, you should have run a printhead cleaning cycle immediately after installing.
Issue: Certain colors are missing or no ink prints on the paper
Solution: Install / replace the recommended ink tanks correctly i550 / i850
Untitled Document
How to install / replace the ink tanks
The ink tanks suitable for the printer are as follows;
Black Ink Tank BCI-3eBK
Cyan Ink Tank BCI-3eC
Magenta Ink Tank BCI-3eM
Yellow Ink Tank BCI-3eY
Note: There are two ink tank label designs.
Operation procedures are shown with label design A.
Replacement Procedure
1. Check that the printer is powered on, and open the front cover. Wait until the print head moves to the center.
2. Remove the empty ink tank by pushing the tab on the ink tank.
Note: When doing this, do not remove the print head. When replacing multiple ink tanks, it is recommended to replace one at a time to avoid inserting them into the wrong slots.
(The image is an example using i850.)
3. Remove the new ink tank from its package. Pull the orange tape in the direction of the arrow to remove it completely, and remove the shrink-wrap film.
Note: Remove the orange tape completely. If the tape remains, printing may not be performed properly.
Confirm that the orange tape is completely removed from the ink tank, as shown in image 1. If the tape is similar to the sample in image 2, remove the remaining portion of the tape so that it looks like the sample shown in image 1.
(1): Correct
(2): Incorrect (where the arrow indicates)
4. Slowly twist the orange protective cap in the direction that the arrow indicates, and remove it. To avoid ink adhering to your fingers, brace the orange protective cap while removing it.
5. Insert the new ink tank to the print head by holding it at a slight angle.
Note: Confirm that the ink tanks are installed in the right order according to the labels on the print head.
6. Press down on the top of the ink tank until a click sound is made.
7. Close the front cover. The next time the printer performs printing, it will automatically start print head cleaning. The power lamp will flash while cleaning is performed. Until cleaning completes, do not perform other operations.
SOURCE: printing blank paper
try a few things, your printer maintenance my need to be adjusted, such as settings. i have one at work and i hate it, canon printers are so non-user friendly. do you have both a black and a color cartridge in it, if so you will have to tell it in the maintenance settings, if you only have one or the other installed you have to put both in it wont print with only one cartridge. if you just bought it and still have everything that it came with...take it back and buy a lexmark.
SOURCE: Canon jP 1500 is printing blank pages
Try a deep clean, sounds like a blockage but odd all at once. it could be possible that cartriges are a faulty batch, ive experienced many times but not all at once. hope this helped jay.
