In the event that you don't approach the Canon printer or on the off chance that you would prefer not to look through the menu framework, discover the canon printer IP address on any PC on which the printer is set up.
FOR WINDOWS
Open Control Panel > Devices and Printers. Right-click the printer and select Properties.
One of two arrangements of tabs shows, contingent upon the kind of association the canon printer driver employments. In the event that the Canon printer is set up under a WSD port, it uses Web Services for Devices innovation to associate with the printer. For this situation, select the Web Services tab to see the printer IP address recorded in the IP address field.
On the off chance that you don't see a Web Services tab, at that point the Canon printer is set up utilizing a TCP/IP port. For this situation, discover the IP address in Printer Properties.
1. In Control Panel, pick Devices and Printers.
2. Right-click the printer and select Properties.
3. Select the Ports tab. The IP address is shown in the Port field.
Port tab of printer Properties with IP address
4. On the off chance that you don't see the IP address, select Configure Port to see the IP address arranged for that printer.
SOURCE: Canon MX700 network problems
Once you have it installed and working on the USB port go to the properties page of the printer.
1) Select the "Ports" tab.
2) Select "Add Port".
3) Select "Canon BJNP Port".
4) Select "New Port".
5) Fill in the IP Address of your printer and select "Next".
Make sure that the Port is checked back in the properties page and
select "Apply" and your done. Do a test print and your printer should
work on your network. You may still need to fix the settings on your
firewall or router to allow access if it does not print.
SOURCE: setting Ip address on canon c3220 imagerunner.
Is the Canon connected with a cable that's connected to an active port. You can try to Fixed IP hold down 1 & 7 When you power up the machine, make the necessary network configurations and see if pings back with a reply.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Iām happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
SOURCE: How to find the IP Address canon IR3570
you should be able to go through the print menu on the printer and look for something that says information or configuration and look for network settings and print this page.
ADDITIONAL FUNCTIONS>SYSTEM SETTINGS>NETWORK SETTINGS>TCP/IP SETTINGS
Testimonial: "Thanks, Can you please advice how do i print network setup page from this printer [Cannon ir3570]"
The printer model MX330 is not capable of printing from an Android device thru USB cable.
check the manual and connect via bluetooth instead.
