https://www.kohler-engine-parts.opeengines.com/.../free-kohler-service-...Kohler Engines and Kohler Engine Parts Store Free Kohler Service Manual Downloads - Listed below are Kohler service repair manual in Adobe PDF format ...
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
It could be fuel pump or carburetor. Make sure tank valve is open (if equipped), remove fuel line from carb and carefully have someone turn engine over, if you get a good stream coming from line you know pump is good, then you know problem is in carburetor. Hope this helps.
technically it is possible to do a heart trnasplant
all you need to check are the mounting flange holes or be able to drill new holes in the mower frame
and next the method of attaching the drive pulley or pto to the crank shaft has to be considered
