20 Most Recent Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Questions & Answers
2answers
Husqvarna LT-18542 lawn tractor dies after it is started. Carburetor was cleaned ignition coil and spark plug are good.
Check that the ignition module and the fuel solenoid remain powered when ignition switch returns to the RUN position.The mOOOoof sound is the leaf valve in the crankcase breather. As the engine spins down and the crankcase pressure drops, the leaf may resonate. Some do some don't.As a test you might try adding fuel (starter fluid, carb clean, or combustible brake clean). Remove the air filter and as it dies spray a shot of fluid into the carb throat. If it picks back up you know it's a fuel problem and not ignition.
2/7/2023 5:19:33 PM • Husqvarna Lawn... • Answered on Feb 07, 2023
5answers
John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
6/13/2020 12:17:28 AM • Husqvarna Lawn... • Answered on Jun 13, 2020
I have a husqvarna 26
The engine is not charging, you need to have the charging system checked out, could be the charging coil or the rectifier.
3/1/2018 3:00:34 PM • Husqvarna Lawn... • Answered on Mar 01, 2018
I have an LGT2654. I broke
Hope this helps. pulley-lvrlm0rty121ep55h51hqhbb-2-0.png pulley 1-lvrlm0rty121ep55h51hqhbb-2-1.png
2/16/2018 10:46:41 PM • Husqvarna Lawn... • Answered on Feb 16, 2018
Will stp s3512 oil filter work for rz5426 husqvarna?
Husqvarna always recommends using the factory approved oil filter. These have the correct micron for filtration, they also have check valves if needed. The filter may attach but may not filter correctly.
1/17/2018 7:50:35 PM • Husqvarna Lawn... • Answered on Jan 17, 2018
I have a husqvarna LGT2554 54" mower will not move do this mean transaxle need to be replaced or a part put on?
If the transmission is a hydrostatic (automatic) and this has been slowly happening, yes the transaxle could be bad and need replacing. If this was sudden, check your belt. If you have recently changed a flat tire, make sure you put the drive key back on the axle.
12/12/2017 6:52:58 PM • Husqvarna Lawn... • Answered on Dec 12, 2017
What is the belt layout for model# 917.287241
w77zwue4gozzgelshllqfzly4mk0tvcfu0eberkv5ixekhiiiioprjaceiiik9wnbcrereeoghhyiiipqcqwsrerhpbyywiiii0gsmlurerkqxgfqiiihilzc0eberkv5gaceiiik9wnbcrereeoghhyiiipqcqwsrerhpbyywiiii0gsmlurerkqxgfqiiihilzc0eberkv5gaceiiik9wnbcrereeoghhyiiipqcqwsrerhpbyywiiii0gsmlurerkqxgfqiiihilzc0eberkv5gaceiiii9apwfiy0jjbrfy3saaaaasuvork5cyii=
12/12/2017 6:30:10 PM • Husqvarna Lawn... • Answered on Dec 12, 2017
I have husqvarna yth1542xp runs about 5 minutes then shuts off. iblew thru gas line towards tank seemed like something was in line or tank. started and it ran another 5 minytes or so and same thing ha
Try it with the fuel cap loose ( not off just loose). This will see if the tank is venting properly. You may also have a bad fuel filter, fuel lines or trash in the tank.
12/6/2017 3:21:58 PM • Husqvarna Lawn... • Answered on Dec 06, 2017
Why won't husqvarna z4217 starter engage after replacing the battery and solenoid
The starter itself may be bad. Are you getting 12 volts to the starter? Does the solenoid "click" when turning the key.
12/6/2017 3:19:08 PM • Husqvarna Lawn... • Answered on Dec 06, 2017
How do I rewire lawn mower
The best way is to order a complete harness. This will cost about $100 but it is the easiest quickest and best way to complete this task.
12/4/2017 7:11:22 PM • Husqvarna Lawn... • Answered on Dec 04, 2017
I have a Husqvarna GT 2548 riding mower with a 25
Hi, It sounds like a lack of fuel supply when it is required. When it idles, the demand is sufficient for this, as soon as a demand is required, there is a lack of fuel supply to meet the demand. Is the fuel old? if it is, you need to drain it and put fresh in. You say it's sat a long time. It's possible that fine particles of metal has built up in the tank and passing up to the carb. You will need to strip down the carb and check to make sure there is no sediment in the float chamber, that the floats are not sticking, and the jets are clear. I hope this is of use. David
12/3/2017 11:35:39 AM • Husqvarna Lawn... • Answered on Dec 03, 2017
3answers
Re: Husqvarna LGT2654... Accidentally hooked up
You may have shorted the battery. Try recharging the battery then try it again.
10/29/2017 12:56:41 PM • Husqvarna Lawn... • Answered on Oct 29, 2017
Replcement oil filter husqvarna model ltg2654
their are a few different filters for your rider --these are for the kohler 26 hp motor stores like home depot- lowes- sears- or small engine repair shops carry filters K&N PS-1002 http://www.sears.com/ayp-genuine-ayp-part-578416804-oil-filter-kohler-cou/p-SPM8242278631?redirectType=SKIP_LEVEL http://www.knfilters.com/oil_filter/all/kohler/sv735/26hp
8/25/2016 1:14:49 PM • Husqvarna Lawn... • Answered on Aug 25, 2016
I have a Husqvarna LGT2654. It is not getting fuel to the carburetor.I checked the fuel filter and it seems ok. what else could prevent fuel from getting to the carburetor?
Sounds like there could be dirt in the fuel jet going into the carb. This will not let fuel into the engine. If that's not the problem the float could be stuck closed in the carb.
8/22/2016 1:08:51 PM • Husqvarna Lawn... • Answered on Aug 22, 2016
Mower shuts off after running about 5 minutes. i blew thru gas line towards tank and seemed like there was resistance tnen it opened up. ran another 5 minutes and same thing happened . model is husqva
Check the fuel tank cap. It needs to let air into the tank and has a small hole to enable this. Try running the engine with the cap loosely in place to verify this is the cause. If you can't clean it get a new one.
7/13/2016 8:30:36 AM • Husqvarna Lawn... • Answered on Jul 13, 2016
Why isn't my john deere lawn mower with 2 cylinder motor still not fixed after changing coil
Depends what's wrong with it. Can you post some symptoms please!
7/13/2016 8:27:11 AM • Husqvarna Lawn... • Answered on Jul 13, 2016
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
342 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
husqvarna lawn tractor dies after
  • Garden
