20 Most Recent Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Questions & Answers
How can I stop the squeak in my Husqvarna steering wheel on my lawn tractor.
Question Edited to what I think you meant to say :>D Question moved from Cars and Trucks category, once again a guess! Please always include 'make model (what it is)' in all questions. WD40 on all linkages, bearing and sleeves from steering wheel to the wheels.
11/17/2021 2:59:21 AM • Husqvarna Riding... • Answered on Nov 17, 2021
Tension spring keeps breaking on deck idler pulley
The same thing has happened to me, twice. The Idler arm bracket has broken in the exact same spot.
7/21/2021 3:43:06 PM • Husqvarna Riding... • Answered on Jul 21, 2021
I reversed polarity when installing new battery
Would like clarification. Is the engine turning over at all? Is the starter pinion engaging? The electric start circuit is totally separate from the ignition circuit and will not affect the running of the engine at all.
4/12/2021 1:21:42 AM • Husqvarna Riding... • Answered on Apr 12, 2021
Mower starts, dies when you release clutch.stumped. is it time to replace mower or is this relatively cheap fix
My Husqvarna 48-Inch Mower Will Not Stay Running ' Home ...
homeguides.sfgate.com > ... > Other Real Estate Terms & Definitions Among its offerings is an extensive list of riding tractors and mowers. ... Mowerissues can prevent you from performing your lawn-maintenance program. ... If yourHusqvarna 48-inch mower dies without spinning down, check the drive belt ... If yourHusqvarna mower runs until you release the clutch, chances are you have an ...
10/27/2020 12:30:57 PM • Husqvarna Riding... • Answered on Oct 27, 2020
How to remove pto on husqvarna lawn tractor
There is a wiring harness plug on the back side of the PTO switch, simply remove the plug, squeeze the two tabs holding the PTO in the dash and slide it out the front side. Reverse for install. ** Disconnect battery cable to be safe.
12/12/2017 7:32:01 PM • Husqvarna Riding... • Answered on Dec 12, 2017
Husqvana ride on mower CTH171.
There is a main fuse and some relays up under the dash board it is an auto motive style fuse
8/28/2017 8:19:39 PM • Husqvarna Riding... • Answered on Aug 28, 2017
I have a husqvarna 4817 zero turn mower that will not start
Bad battery, or solinoid.
8/20/2017 9:10:03 PM • Husqvarna Riding... • Answered on Aug 20, 2017
I have a yth2448 , and when I engage the mower
Disconsolate the connector from the clutch. Engage the clutch circuit and see if electrical circuit still response as if shorted. If the response is the same check wiring, switch and relay. Replace/repair defecrive component. If the response is no problem check the clutch. Inspect the connector at the clutch for broken failed wire connection. Using an ohm meter check for short. The expected resistance is about 3 -4 ohms. If the resistance is less then 1 ohm the PTO clutch is bad. Sorry. It is the solenoid coil has an internal short. Confirm if the clutch is still in warranty. Check for after market sources for reduced price! s-l1600-ye4zlyuovxg25rnpc03q42bj-3-0.jpg Hope this helps?
6/23/2017 5:16:52 PM • Husqvarna Riding... • Answered on Jun 23, 2017
How to install clutch spring
This is not something for the novice. The clutch, if not properly installed or repaired can explode and cause personal and property damage. I would suggest the authorized dealer to make this repair.
2/22/2017 2:49:20 PM • Husqvarna Riding... • Answered on Feb 22, 2017
2answers
Riding mower accelerates extremely slow
hydrostatic transmission failure, get your wallet out as they cost almost as much as a new mower
7/14/2015 12:35:42 PM • Husqvarna Riding... • Answered on Jul 14, 2015
MY TRANSMISSION IS VERY WEAK,
noted for frequent failure of hydrostatic transmissions, just search this site. you have to buy another transmission or lawn mower.
6/15/2015 8:08:29 PM • Husqvarna Riding... • Answered on Jun 15, 2015
2answers
How could gas be entering the crankcase of my Husqvarna 48" riding lawn mower?
Sounds like you have a hole 'burnt' in the piston top allowing fuel combustion mixture (normally compressed above the piston) getting down into the crankase or that the piston rings are shot allowing the same thing. As the piston is continuously moving, the reverse happens giving oil at the intake or carb. . Looks like a strip down, good inspection and rebuild of engine required .
9/20/2014 5:52:57 PM • Husqvarna Riding... • Answered on Sep 20, 2014
Gas is getting into the crankcase and diluting the oil/
I have a Robin or as they call it now Subaru engine with this same problem when it stopped the petrol flow into the crankcase. The fuel tap close it when finished and put the engine on TDC then no problem anymore. Check the tap if it REALLY closes as tge only other problem I had was dirt in the carburettor. I cured this with an inline fuel filer
9/20/2014 4:33:09 PM • Husqvarna Riding... • Answered on Sep 20, 2014
How to remove fuel tank on 48 inch husqvarna riding mower
pull the rear seat/fender assy... the floor boards ( where your feet sit ) have a couple of bolts, then the seat springs have a couple of bolts... a couple of handles might have to be removed...
8/30/2014 1:43:40 AM • Husqvarna Riding... • Answered on Aug 30, 2014
2answers
Won't Fully Engage Drive Gears
If the machine has been sitting idle for a period of time it is probable that the cutter spindles have failed / rusted bearings. They suffer from wet grass/ water seepage when working and when let stand idle for a time will rust up the balls in the bearings. Loosen the drive belts and see if the cutters can be turned freely by hand .
8/29/2014 12:40:21 AM • Husqvarna Riding... • Answered on Aug 29, 2014
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
245 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
  • Garden
