SOURCE: black and decker mm675 lawn hog
Wedge a short piece of 2x4 between the blade and the housing,
turn clockwise to tighten !
SOURCE: wishbone front offside bmw mini one
you have to put the wishbone on 1st, the ball joint nut on and the front one den guide it in the hole and use a big lever with plenty of wd 40 and it will go in, i jus did one the other day, i had to change dat rear wishbone bush which was a nightmare to do
SOURCE: can't remove the nut holding blade on. Which way do I remove
Get some WD-40 and spray the area around the nut then let it sit for a few hours. This will get into the threads and loosen any rust that is compounding your problem. Now get a good wrench and look directly at the nut. Left is loose and Right is tight.
SOURCE: How do I remove the wheels on a 1985 Troy Built Horse Rototiller?
Horse wheels are held on with a single roll pin. Pound out the roll pin and pray.....that the rims aren't rusted to the shaft. If the rims are rusted to the shaft, you have two choices. You can either put the new tires or tubes on the rim with the rim on the shaft...or you can work at getting the rims off the shaft. If you put tubes in, be sure the rim is free of sharp edges.....or you'll be sorry.
To get the rims off if they're rusted on, I've used a variety of techniques over the years. The most effective is to weld a nut on the spot where you removed the end caps. Use a nut that's the same thread as your bearing puller. Then use the bolt from your bearing puller to put pressure on the end of the shaft, pulling the rim off. A torch helps, but be careful or you'll be putting new seals in too.
SOURCE: How do I remove the blade from a Makita MK470 tile
There is not a lock on this saw. If the blade is to tight to hold by hand you need to use an impact wrench. It will loosen the nut before the blade has time to start spinning.
