20 Most Recent King Kutter Rotary Tiller Pto Bush Hog John Deere Long Questions & Answers
lift The brush hog up and place on blocks or other foundation that wont fall over. disconnect the power take off shaft from the tractor. Now look for two round openings in the middle of the deck one on ether side of the gear box (the thing on the brush hog that the pto shaft from the tractor hooks up to to make it spin there might be a slip clutch on the shaft but go to the box in the middle) Now turn the shaft till you see the blade nuts in the hole These could be castle nuts with a small carter pin locking them so they don't unscrew. Remove the pin and with a large socket set unscrew it from the bolt then knock the press fit bolt down and the blade will come off, do the same to the other blade if you need them both off. To put them back on use something under the blade and bolt to hold it up so you can start the nut then reverse the order and put everything back on. The blade bolt might be stubborn to get out just take something that fits through the access hole like a wood doll or long punch and drive the bolt down till it comes out as it is press fit and is jammed up to keep the bolt from turning, when putting it back on you will need to make it tight so the bolt can repress back in. Be Careful when reaching under to set the blade and bolt back in. There is not much you can mess up it is just a big nut and bolt Just make sure you put the blade on the way it came off if you do one blade or one at a time you can look at the other to see which way it goes.
King Kutter... | Answered on Oct 06, 2014
You are talking about a three point hitch ... they can be tricky. Might be worth the time to go to the farm supply store in your community and take a look at how it should be hooked up and operated. It is dangerous to operate this device with out some training.
King Kutter... | Answered on May 03, 2011
most warranty on tillers is 1 to 2 years depending on the brande, also it must be a MF defect. if the shaft broken for improper uses you may have a problem. warranty service centers well know what happened and how it broke. call your 800 number in your book also it gives you your warranty info there to.
King Kutter... | Answered on Oct 13, 2009
What make of motor and HP of mower motor? https://www.6ya.com/callphilipforhelp
Garden | Answered 1 hour ago
how would we know?? its your mower
Garden | Answered 2 hours ago
According to the manual ''The engine serial number is located on the right side of the engine crankcase''
Link for manual for your reference >
https://www.manualslib.com/manual/1235821/Kioti-Dk451.html
Garden | Answered 9 hours ago
Why does my cutter blade keep slacking off
Garden | Answered 16 hours ago
King Kutter Rotary Tiller Pto Bush Hog John Deere Long Logo
5 questions posted
Top King Kutter Garden Experts
Jay Finke
Jay Finke
George Merkley
George Merkley
john h
Are you a King Kutter Garden Expert? Answer questions, earn points and help others
View Most Popular
King Kutter Garden
  • King Kutter Garden
Most Popular Question
change blades 5ft bush hog
  • Garden
