Dryer was working then would stop mid cycle. I unplugged dryer to reset and plugged back in. Now no power.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at [email protected] with your name, address, phone number and the model & serial numbers of the Dryer.
SOURCE: Whirlpool Dryer LER7646EQO - Won't Start
my whirlpool electric dryer not turning,there anyone can help
SOURCE: whirlpool cabrio steam electric dryer has sensor light on and does not work
have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
SOURCE: admiral capacity plus stopped working mid cycle no power
When u press the knob to start the dryer is there a buzzing noise ???
If so i guess u nee to order a new moter ...
u can do it at..www.appliancepartspros.com
SOURCE: Control Panel in my whirlpool duet dryer model
First check for 220 volts incoming power to the dryer at the terminal block on the rear of the dryer.
If you have 220 volts,check continuity on part number 59(thermal fuse) in the attached diagram. No continuity is a bad part.
cut and paste this link to your dryer diagram.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5139909&diagram_id=951915#d951915
SOURCE: My whirlpool cabrio front load dryer will power on
underneath the lint trap is a sensor, it will need to be cleaned. Good luck Tim
