20 Most Recent Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Questions & Answers
AF on your Cabrio means the Air Flow is being obstructed. Make sure the vent is secure and free of debris at the back of the appliance. Also ensure there is no obstruction where it is vented outside of your home. Lastly, make sure the lint trap is clean. Your dryer will still run normally, but it's best to go through your checklist so no further issues arise.
Whirlpool Cabrio... | Answered on Sep 10, 2019
Depending on the dryer, it could simply be the wrinkle guard setting. This is the case with my Kenmore (Whirlpool) dryer.
Whirlpool Cabrio... | Answered on May 02, 2019
The ring around the top is for ballance with fluid in it. That wouldn't be it. On some there's 3 parts the stick up on the inside of the tub that are held on with 2 or 3 screws . sometimes coins or something gets through a crack and will rattle . The screws go in from the other side of the drum you can turn the drum to get to them. Take them off and remove coin or whatever. Will have to take the top off to get to it.. Hope this helps good luck.
Whirlpool Cabrio... | Answered on Jul 16, 2018
I agree. It's rotten to have someone check out your product and then have it stop working. You probably have a problem with your ignition panel.This is the part of gas dryers that gets hot. When it reaches a certain temperature it causes the pilot light to ignite. It sounds as if your ignition needs to be replaced. We did this and had another 6 years from our gas dryer.
If you're handy you can probably do this replacement yourself. If you're like my spouse and me, we found a reasonably priced professional who completed it in just a few minutes.
Good luck. I hope this helps you. If it does, please come back to Fixya and rate my help!
Whirlpool Cabrio... | Answered on Feb 23, 2018
When I turn the dryer on say to 40min,it shows does not come on and it goes to a F1 on the daily
Whirlpool Cabrio... | Answered on Dec 28, 2017
This may be a structural defect and not repairable.
Whirlpool Cabrio... | Answered on Sep 21, 2017
We are sorry to hear of the problem with your Whirlpool Dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your Dryer.
Whirlpool Cabrio... | Answered on Apr 18, 2017
there is nothing to calibrate
if it has been repaired properly, adjust the water level setting , wash requirement , soak period , deep rinse settings etc as to what you want and switch it on
Whirlpool Cabrio... | Answered on Apr 19, 2016
Then it could be the door switch, did you check that. And did you check all the limit switches? As well did you turn the drum by hand, does it feel like the belt is still connected?
Whirlpool Cabrio... | Answered on Mar 08, 2016
check the power supply to the unit. if no voltage is found on the unit . check the wall outlet.no power at the wall socket ?? check the breaker box for tripped breakers if breaker to the wall outlet is off but good ,leave as is . check for grounds at the unit . if no grounds are present , turn on breaker . if it breaks with the dryer still not plugged in , search for any appliances connected on that line and unplug all. plug in the dryer then start it .if breaker opens , something is wrong with the dryer. call a qualified technician . thanks .
Whirlpool Cabrio... | Answered on Mar 04, 2016
Replace the thermistor to restore normal operation. It opens when appliance gets to certain temperature and then closes again to restore heat. That sucker will never work until you get a good thermistor in there.
You can always jump it and get heat but there is no safety valve in case unit overheats - could have a fire. Your call, your life.
Whirlpool Cabrio... | Answered on Feb 14, 2016
Inlet Thermistor Open F-24 flashes if the inlet thermistor is open. This fault code will ONLY appear when in the diagnostic test mode. See TEST #4a.
http://dryernotheating.net/whirlpool-cabrio-dryer-error-codes/#F-24
Your thermal cut out relay may be bad, your heating coil may be bad, but be sure to check lint filter and the vent pipe before checking the thermal cut out and heating element
Whirlpool Cabrio... | Answered on Oct 04, 2015
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
349 questions posted
Top Whirlpool Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Dryers
  • Whirlpool Dryers
Most Popular Question
code f24 mean whirlpool cabrio dryer
  • Dryers
