That message appears if the shut down process is not followed.
power failure , emergency shut down or other problems that just shut the pc down will result in files and folders becoming corrupted and not saved
when booting up if the message appears that states start in safe mode , start normally etc , click on start normally
SOURCE: I had an improper shut
Try Restoring the System to an earlier date and time. Boot your laptop and press F8 after the POST and you will see a list of options provided.
Select safe mode with command prompt and logon.
At the command prompt type rstrui.exe
this should give you the system restore utility and you can use that to restore your system
