20 Most Recent Acer Aspire One Netbook 8.9" Notebook Questions & Answers
Have you checked the encription method (WPA or WEP) - usernama and password or just a password for the second type
Acer Aspire One... | Answered on Aug 28, 2018
Your problem can be cured by simply increasing your paging file size or adding more Ram. Here is an explanation of what an API is and does.
An application programming interface (API) is an interface implemented by a software program to enable interaction with other software, similar to the way a user interface facilitates interaction between humans and computers. APIs are implemented by applications, libraries andoperating systems to determine the vocabulary and calling conventions the programmer should employ to use their services. It may include specifications for routines, data structures, object classes and protocols used to communicate between the consumer and implementer of the AP
Acer Aspire One... | Answered on Jun 12, 2018
  1. Click on Start and then Control Panel.
  2. Click on the User Accounts and Family Safety link.
  3. Note: If you're viewing the Large icons or Small icons view of Control Panel, you won't see this link. Simply click on the User Accounts icon and proceed to Step 4.
  4. Click on the User Accounts link.
  5. In the Make changes to your user account area of the User Accounts window, click theChange your password link.
  6. In the first text box, enter your current password.
  7. In the next two text boxes, enter the password you would like to start using.
  8. Entering the password twice helps to make sure that you typed your new password correctly.
  9. In the final text box, you're asked to Type a password hint.
  10. This step is optional but I highly recommend that you use it. If you try logging in to Windows 7 but enter the wrong password, this hint will display, hopefully jogging your memory.
  11. Click on the Change password button to confirm your changes.
  12. You can now close the User Accounts window.
  13. Now that your Windows 7 password has been changed, you must use your new password to log on to Windows 7 from this point forward.
If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
Acer Aspire One... | Answered on Mar 18, 2018
It means that either your boot files or your operating system is corrupt. You need a system repair disc or a operating system disk to fix the problem. One other problem could be that your hard drive has crashed and you lost everything, but I don't think that's your issue.
Acer Aspire One... | Answered on Mar 09, 2018
Ask acer for this problem, when you buy a laptop you need to make recovery discs, you prolly did not do that. So now it asks for recovery files on the dvd disc.
If it has no dvd drive you should have made them on a usb drive.
If acer cant help you with that, reinstall windows thats the only option.
Partitions hidden can be removed but then there is no way to restore the pc to factorydefaults anymore.
When you decide to reinstall windows, you will see 3 partitions, remove them all, then make 1 partition click next and it will make a little partition for system files. the rest is used for windows, untill u partition the rest, like a d: e: drive.
Acer Aspire One... | Answered on Feb 13, 2018
only you would know the answer to this question.
Acer Aspire One... | Answered on Feb 05, 2018
when you reboot the computer to start in safe mode by pressing F8 key and then try to change the resolution of the monitor.
Acer Aspire One... | Answered on Dec 29, 2017
Try this
Unplug the power cord from wall and from computer completely
Remove the battery from laptop
Wait about 1 min.
Then replace the battery then the power cord
Turn laptop on
Acer Aspire One... | Answered on Nov 08, 2017
Try rebooting using the original the original Windows that came with your computer
in windows 7 F8 is the key of enable safemode
Acer Aspire One... | Answered on Oct 07, 2017
Privacy Center, or PrivacyCenter, is a rogue anti-spyware program designed to trick users into purchasing its full rogue version. Privacy Center looks similar to Privacy Components. Privacy Center may infect your computer through a Trojan, spam emails or it may have come bundled with another malicious program. Privacy Center sells itself as an effective spyware remover tool, however, all it does is make you believe you're infected with numerous spyware threats to offer its "licensed" program.
Go to the link below and download and run MalwareBytes Anti-Malware program. When it installs it will ask to update and run, please do both. Once it updates, run the program and perfrom a QUICK scan only. When it is through scanning it will ask you to click on the show results button. When you do that it will show you the infections it has found, make sure they are all selected and delete them. You should be malware free now.
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=mncol
Acer Aspire One... | Answered on Dec 27, 2016
Try a different set of headphones, it sounds like the computer is not recognizing that the headphones are plugged in. Does the computer put sound out through the headphones as well?
Acer Aspire One... | Answered on Dec 14, 2016
Whatsapp is for mobile phones.
Acer Aspire One... | Answered on Oct 27, 2016
You should start windows in safe mode. By pressing the F8 key right when Windows starts, usually right after you hear your computer beep when you reboot it, you will be brought to a menu where you can choose to boot into safe mode. If it does not work on the first try, reboot and try again as you have to be quick when you press it. when it starts in safe mode, run system restore and when prompted for a restore date, choose an older restore date, probably one you a sure was perfect 2 days before the blue screen issue. This should get your system running in good shape.
Acer Aspire One... | Answered on Aug 27, 2016
1. Install another browser: For e.g. FLOCK
2. Are you able to browse?
If so then we have isolated the problem to Internet Explorer:
1. Which version of IE are you using?
Either way:
1. uninstall it completely
2. Download and reinstall the latest version of IE
And just in case please do a VIRUS SCAN:
1. DiskClean up of C drive (always do this before a virus scan)
2. Total Virus Scan of Hard Disk (make sure Virus application is updated first)
About System Restore:
Windows does not allow you do to a restore from before it happened because it did not save any restore date from prior to (perhaps system restore is not enabled so be sure to double check this); therefore:
1. You're going to have to try to fix this isolated problem manually
OR
2. RESTORE to factory settings: take all ur data off and restore to factory settings and then put ur data back thereafter.
CAH
CAH
Acer Aspire One... | Answered on May 06, 2016
To install a different language - Multilingual User Interface (MUI) - you need to have Windows 7 Ultimate.
Anytime Upgrade to Windows 7 Ultimate
Type Anytime Upgrade in the Search programs and files box in the Start menu and click on the Windows Anytime Upgrade icon. From there, you can buy an Anytime Upgrade to Windows 7 Ultimate. Then your can enter your Anytime Upgrade product key and perform a simple upgrade to Windows 7 Ultimate so you can install a different language.
If you are in Australia, Belgium, Canada, France, Germany, Italy, Japan, the Netherlands, Spain, Sweden, Switzerland, the UK, and the US you can use Anytime Upgrade. If not you will need to buy Windows 7 Ultimate, or buy Windows 7 in the language you need.
http://windows.microsoft.com/en-us/windows7/products/windows-anytime-upgrade
Install Language Pack in Windows 7 Ultimate
1. Start -> All Programs --> Windows Update --> Optional Updates.
2. Open optional Updates and go to the section Windows 7 Language Packs.
3. Tick the Language Pack you want and hit OK
4. Proceed with Install Updates
5. Depiction of Windows 7 downloading a Language Pack
6. Automatic install initiated after download
How to change the Windows 7 Display Language:
1. Go to Start -> Control Panel -> Clock, Language, and Region / Change the display language
2. Switch the display language in the Choose a display language dropdown menu.
3. Click OK
4. Log off for the changes to take effect (This will affect only the user profile under which you are currently logged on).
Acer Aspire One... | Answered on Apr 21, 2016
Wifi is a just mode of connectivity, does your wifi access point or router has connection to internet ?
if yes there is configuration issue most like gateway ip address
if no its obvious u should get a internet connection
wifi is nothing but a Wireless local area network
Acer Aspire One... | Answered on Apr 20, 2016
Acer Aspire One Netbook 8.9" Notebook Logo
2,451 questions posted
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
insuffient system resources exist
  • Computers & Internet
