When tub is filled on a Pearl Baths jacuzzi
SOURCE: Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
SOURCE: I purchased my pearl jacuzzi tub about 16 years
A company called Maax bought Pearl. They are out of Canada, It would be the first place I would check, they have a website Maax.com
SOURCE: My jacuzzi bathtub plastics pipes underneath are
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
SOURCE: My jacuzzi tub motor will hum but does not run. I
I had this same problem. I looked at the motor, and on one end (the end opposite where the water comes out) there is a hole in the middle. In that hole is a regular screw tip, which can be used to turn the motor. I filled the tub, inserted a slotted regular screwdriver and turned it about 8 times clockwise, then 8 times counterclockwise. You should see the whole motor turn. Doing this loosened it up, and then it started.
Once it started, all kinds or residue came out, which was probably why it had stopped working. I hadn't used it for a while.
After getting it running I'm going to run some cleaning solution through it, and make sure I run it more often to prevent this in the future.
