20 Most Recent Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump... Questions & Answers
I had this same problem. I looked at the motor, and on one end (the end opposite where the water comes out) there is a hole in the middle. In that hole is a regular screw tip, which can be used to turn the motor. I filled the tub, inserted a slotted regular screwdriver and turned it about 8 times clockwise, then 8 times counterclockwise. You should see the whole motor turn. Doing this loosened it up, and then it started.
Once it started, all kinds or residue came out, which was probably why it had stopped working. I hadn't used it for a while.
After getting it running I'm going to run some cleaning solution through it, and make sure I run it more often to prevent this in the future.
Jacuzzi EH0 /... | Answered on Mar 04, 2018
Try and blow the lines out with air, sounds like something is stuffing the water jet. Drain system and turn off power first.
Jacuzzi EH0 /... | Answered on Feb 15, 2016
replace pump.
Jacuzzi EH0 /... | Answered on Feb 10, 2016
Shut water off and remove knobs. Replace valves on side leaking. Go to Home Depo they will help.
Jacuzzi EH0 /... | Answered on Feb 09, 2016
look on the back of the motor there should be a shaft that you can try to turn to spin free because something inside the pump is blocking it. rate me if this is helpful.
This sounds like maybe you have a bad circuit on the control that turns the pump on/off.
Get the model number off the control box under the tub and let me know what it is and we can solve that issue for you.
Rod
US Parts Center
888-521-6183
Jacuzzi EH0 /... | Answered on May 05, 2014
How do you turn this on? If it is an air button that you push, it may well be the air switch in the motor is bad. The air switch is latching so when you push the button on the tub it closes the switch and lets the power go to the motor. When the button is pushed a 2nd time the switch will open and shut off the power going to the motor.
An air switch will cost about $21 to purchase.
Rod
US Parts Center
Jacuzzi EH0 /... | Answered on Jan 16, 2014
If you press the air button in and it does not turn the pump off you need to check a couple things.
  • is the hose still attached to the bottom of the air button and the air switch on the pump
  • check the air switch in the motor - it probably needs to be changed.
US Parts Center
Jacuzzi EH0 /... | Answered on Sep 04, 2013
Yes you can check a pump with no water in the tub.
What kind of issues are you having with the pump?
US Parts Center
Most bathtubs have a low water sensor on the wall of the tub and the water has to be above that in order for the motor to operate.
US Parts Center
Open the access panel and see if the motor is working or just trying to work. Sounds like it may need lubrication.
Jacuzzi EH0 /... | Answered on Feb 08, 2013
you mean the drain or the room?...drain= definitely yes. room= good idea
Jacuzzi EH0 /... | Answered on Jul 27, 2011
http:rad.yahoo.===== http://www.bingstore.us =====
50%off ca,ed hardy t-shirt$15 jeans,coach handbag$33,air max90,dunk,polo t-shirt$13,,lacoste t-shirt $13 air jordan for sale,$35,nfl nba jersy for sale
puma gucci$35,nike jordans six ring,yeezy$%5!!
new era caps$13 gucci handbags jeans,t-shirts sunglass,caps
true religion jeans$35,ca,ed hardy jeans$35
LV,CHANAL,HANDBAGS$35
NIKE SHOX+AIR MAX+TL3+OZ+NZ ONLY $35
UGG TIMBLAND+LACOSTE SHOES+ED HARDY SHOES$35
DIESEL T-SHIRT,GSTAR T-SHIRT,CA T-SHIRT,50% OFF FOR SALE $15
DIOR SUNGLASS,DG SUNGLASS$15
our website: ===== http://www.bingstore.us =====
Jacuzzi EH0 /... | Answered on Jun 21, 2011
have you checked for cracks in the fiberglass body?
Jacuzzi EH0 /... | Answered on Apr 11, 2011
It kind of sounds like you have not purged air from near the pump impeller. Try adding water through the filter, often times this forces prime.
Jacuzzi EH0 /... | Answered on Jan 16, 2011
Jacuzzi EH0 / EH1 / EG9 Fuzion 6666 Corner Whirlpool with Right-Side Pump... Logo
59 questions posted
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
View Most Popular
Jacuzzi Home
  • Jacuzzi Home
Most Popular Question
jacuzzi tub motor will hum but not run
  • Home
