20 Most Recent Whirlpool Pearl Navarre 7242 True Bathtub with Back Massage - 103558-100 Questions & Answers
Gold neck water jet spout has been replaced four times in the past year by different plummers; I called help line and said to heat up---so they heat it up and shove it in the white port---the very nex
sounds lie you have push in quick connect fittings if so the the push in hose is the wrong size otherwise change the fittings to proper olive connections
9/16/2017 10:32:25 AM • Whirlpool Pearl... • Answered on Sep 16, 2017
Jets won't pump water
Air Switch Repair It sounds like you have a bad air switch located in your motor. The air switch is what the air hose connects to on the back of the motor or on the box on top of the motor. The other end of the air hose is connected to the air button on the lip of the tub. This is a latching air switch and when you push the air button it latches to send power to the motor. When the air button is pushed again it opens the latch in the air switch and stops power going to the motor shutting it off. US Parts Center
2/26/2014 11:30:07 PM • Whirlpool Pearl... • Answered on Feb 26, 2014
I need to know how
Disconnect the power for a min or two and then turn it back on this should reset everything back to default. Then go through the setup instruction as if you were starting new. If that dosen't do it the control unit is faulty.
2/1/2011 8:53:09 PM • Whirlpool Pearl... • Answered on Feb 01, 2011
I need new trim parts to change from gold to
go to http://www.uspartscenter.com/shopbybathmfg.aspx you should be able to find the parts for your tub there.
12/22/2010 6:55:35 PM • Whirlpool Pearl... • Answered on Dec 22, 2010
I purchased my pearl jacuzzi tub about 16 years
A company called Maax bought Pearl. They are out of Canada, It would be the first place I would check, they have a website Maax.com
7/4/2010 2:48:22 AM • Whirlpool Pearl... • Answered on Jul 04, 2010
Can you add options on to an existing pearl
hi iwould go on wirlpools internet site they have an help desk there also shopping basket
11/16/2009 8:05:23 AM • Whirlpool Pearl... • Answered on Nov 16, 2009
Parts for my pearl corner tub
any plumbing suply house would have it. good luck
2/21/2009 1:21:27 AM • Whirlpool Pearl... • Answered on Feb 21, 2009
What products to us in my jet bath
Bubble bath is definitely out of the question. Provide any of the products that you are using do not have a detergent base or bubbles so to speak, you can use them. Depending on how many times a week you use it you might want to get a cleaner that they use on hot tubs from you local pool distributer. I hope this helps you.
11/27/2008 12:49:04 PM • Whirlpool Pearl... • Answered on Nov 27, 2008
Bath Operating Cost
No more than any other household major appliance. The motor, heater, and any other options are standard 110 volt so the average cost to operate your whirlpool is only pennies a day.
8/27/2008 12:30:07 PM • Whirlpool Pearl... • Answered on Aug 27, 2008
How to clean jet on whirlpool tub
first of all you need to be draining the tub completely and removing any bath mats or items from inside. Fill the tub with hot water, ensuring that the jets are covered. You can use white vinegar, 2-3 cups of white vinegar directly to the water in the tub. Turn on the whirlpool system and run it for 15-20 minutes. While the jets are running, use a soft-bristled brush to scrub the jet openings and the interior walls of the tub. Drain the Tub: Refill the tub with clean water and run the jets again for another 10-15 minutes to rinse out any remaining cleaning solution. This should help. This is what I did with mine
4/10/2024 6:31:58 AM • Whirlpool Home • Answered on Apr 10, 2024
Is there anyone in Santa Fe, N.M. able to cap off and permanently seal the six jets on an older Lasco whirlpool type bathtub? And if so what would you charge for this? Thanks!
Didn't I answer this yesterday? I said a local plumber, a spa pool shop, fill them with silicone if you aren't going to use the jets again, or just replace the tub if it is leaking. We don't charge for anything. We are Fixya, we only supply information, nothing else. Fixya isn't really the place to ask for quotations. General plumbers https://www.google.com/search?q=santa+fe+nm+plumbers or specialist plumbers for spa baths https://www.google.com/search?q=santa+fe+nm+spa+bath+plumber ..
2/8/2024 11:06:42 PM • Whirlpool Home • Answered on Feb 08, 2024
Duracraft Plastics Schedule 40 bath drain in a Lyons plastic whirlpool corner tub; Foot Lok stopper will not go down; tried cleaning still cannot unscrew it to clean and clear blockage. Any ideas?
One of these? https://www.amazon.ca/Bath-Drain-Foot-Lock-Plastic/dp/B00L66HVWM Can't you get a drain snake down the side, or these are very effective for pulling long hair blockages and are flexible enough to easily go around corners. I use mine every 6 months. The Green Gobbler cleaner is also very good, or use Draino Gel. https://www.amazon.ca/dp/B00IJFU440/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B00IJFU440&pd_rd_w
Green Gobbler Dissolve Hair and Grease Clog Remover
Home Depot https://www.homedepot.ca > ... > Drain Cleaners Highly effective against grease, hair, soap, and fats. Green Gobbler Dissolve Drain Clog Remover is odourless, nonflammable, and safer to use than ... $18.98 ..
1/27/2024 12:40:21 AM • Whirlpool Home • Answered on Jan 27, 2024
Aquaglass whirlpool tub on/off toggle switch
There is help and videos in this link https://www.google.com/search?q=aquaglass+tub.+replace+toggle+switch If it is completely enclosed, a plumber will normally make an inspection panel from the other side of the wall to gain access. https://www.google.com/search?q=aquaglass+tub+installer ..
9/26/2023 5:17:26 PM • Whirlpool Home • Answered on Sep 26, 2023
I have a Pearl whirlpool tub. The motor stopped working without any warning signs. I'm realizing Pearl motors are no longer being made. I had an electrician check power and he said it was fine. Any suggestions as to what / where I go to resolve this??
every motor has a frame size and horsepower listed on it. search for a new one that way. i would think since its driving a pump it will need to be a totally enclosed/driproof model
11/10/2020 9:07:07 AM • Whirlpool Home • Answered on Nov 10, 2020
K-792-HE whirlpool tub pump powers on but no jets.
Did you turn the outer rings on the jets? They could be turned off. They are used to adjust the bubble flow, but also to turn them on or off.
1/20/2019 1:05:44 AM • Whirlpool Home • Answered on Jan 20, 2019
2answers
Galbocca tub with jets
You have some bacteria build up on the inside of your tubing of the tub.Try some cleaning solutions per directions on the bottle of tub cleaner made specifically for this situation.Cleaning Solutions US Parts Center
9/23/2018 6:21:51 AM • Whirlpool Home • Answered on Sep 23, 2018
Galbocca bathtub with jets
I have galbocca jet tub which is no longer working. I live in Lawton, ok. No one works on them here. Any suggestions?
9/21/2018 5:53:01 PM • Whirlpool Home • Answered on Sep 21, 2018
Whirlpool Pearl Navarre 7242 True  Bathtub with Back Massage - 103558-100 Logo
Popular Tags
15 questions posted
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Home
  • Whirlpool Home
Most Popular Question
purchased pearl jacuzzi tub about 16
  • Home
