20 Most Recent Whirlpool 5"x36" White Bathroom Drop-in Bathtub Spa Jet Questions & Answers
maybe you could photograph the logo and then go into google images and search the photo image against googles massive list of images to see if a match can be made to it
Whirlpool 5"x36"... | Answered on Aug 23, 2016
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Whirlpool 5"x36"... | Answered on Oct 08, 2015
the easiest thing (maybe) is to install an air switch kit on the side of your tub. Here is a link to the part. Basically you install an air button on the side of the tub, install the air tubing from the nipple on the underside of the air button to the nipple on the box that plugs into an outlet under the tub. The pump plugs into that same box and the air tubing from the air button pushing onto the nipple on the box. When you push the button on the tub it will turn the pump on/off. Air Switch Kit
Whirlpool 5"x36"... | Answered on Nov 09, 2014
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link to the cleaning products I can find right now. There may be other out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Whirlpool 5"x36"... | Answered on Nov 15, 2013
There currently is no option for closing the jet openings for any jetted bathtub produced.
US Parts Center
trying to fix button not a good idea,you need to replace button with new one.
Whirlpool 5"x36"... | Answered on Oct 10, 2011
This is a code based issue, and you MUST, MUST have a GFCI (Ground fault circuit interrupter) The tub should have the capacity specified on its box, somewhere. This job requires a permit in most areas, and serious liability exposure is present, and your insurance may not cover, without permits and inspections....
Whirlpool 5"x36"... | Answered on Feb 28, 2011
You can go to any metal part of the tub or electrical part (motor - valve - connection) and fasten a ground wire to that part using a nut and bolt or screw. I would suggest you use a screw that is already on the motor. Run the ground wire to a known good ground. The ground doesn't necessarily have to be the electrical outlet (a cold water piper, for example). There is that possibility that there is nothing metal that you will find exposed. That makes it a little tougher. If this tub came this way from the manufacturer (two prong plug), it is probably exempt from the grounding requirement. I would suspect that the manufacturer wants you to plug this device into a GFI. You can get a GFI at any store that sells electrical parts. A separate ground is NOT required for full protection when using a GFI. All consumer grade GFI (they look like a regular, rectangular outlet) come ready to accept a three prong plug and there will be a place to fasten your house wire ground to the device. As I said, the ground it not a requirement for correct and complete function of the device. If you don't have a GFI available where you are connecting the plug, change it or get a qualified electrician to change it for you. DO NOT, UNDER ANY CIRCUMSTANCES, PLUG THIS DEVICE INTO A STANDARD OUTLET . Use it only on a GFI protected circuit. The outlet you are considering may already be protected by a GFI breaker. You can only prove this by finding the breaker, turning it off and checking the outlet in question. If it is a GFI breaker, it will look different from the others - and have a test button on it. If you are unsure, replace it with a new GFI breaker. I suppose I should also say here that you should check with yout town building inspector as to the requirements before you proceed, so you will meet any local code requirements. If you live in North America, I am certain the GFI is a requirement for this installation, as the National Electrical Code requires it, (Canada and USA).
Thanks for your question here @ FixYa.com today.
Whirlpool 5"x36"... | Answered on Jan 06, 2011
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Whirlpool 5"x36"... | Answered on Nov 20, 2010
depends on if you can get to the air button body. if you can get to it without removing the tile then you can change the button. Sounds to me like you might need to remove the tile to get to the button body because the button body is threaded with a nut threaded onto it to hold the body in place.
Whirlpool 5"x36"... | Answered on Sep 06, 2010
no there is no solutions for plugging off the jets so the water doesn't go in them. you will have to pull the tub and repair the lines. no access panel just means you have to dig in!
I first would test the on/off switch.
Disconnect the wiring. If the tub shuts off, that would be a sure sign.
You can test it while disconnected by using an ohmmeter on the ohm setting, place a probe on each wire connector on the switch. Should have a good reading with the switch on and no reading with the switch off.
Whirlpool 5"x36"... | Answered on Aug 07, 2010
get a bb gun an some rat traps and some raid, if you live in the country this going to happen find out where they are coming in at and close it off and unless you built your house out of "nuts" it shouldnt be problem to keep such retarded animals at bay
Whirlpool 5"x36"... | Answered on Jul 22, 2010
A plumbing shop .Speak to a maneger ,they should be abel to ogenize it. They have sertenly helpt me over the years with some weard things.
And be sure to tell them only the button. maby they will even give u a substetute
Whirlpool 5"x36"... | Answered on Jul 18, 2010
This is known as the purge cycle, it is very normal. It is to blow out any remaining water from the air jets. If it was to allow water to stand in the pipes, it would start to smell and grow algae, which would then clog the small air holes, nothing to be alarmed about.
Whirlpool 5"x36"... | Answered on Mar 26, 2010
Whirlpool 5"x36" White Bathroom Drop-in  Bathtub Spa Jet Logo
30 questions posted
Top Whirlpool Home Experts
US Parts Center
US Parts Center
Donni Steen
Craig Butler
Craig Butler
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Home
  • Whirlpool Home
Most Popular Question
royal bath tub leaves residue each time
  • Home
