20 Most Recent Whirlpool Safety Bath Walk In Bathtub - Stretch Without Questions & Answers
The control & pump you have is no longer being made. (It hasn't been made for well over 5 years)
Your new system will include the following items:
· New Pump
· AirStreme Control box and topside control
You will change out everything from the old system with the new system.
The new topside panel replaces the one on the top of the bathtub and the pump will hook up to the same plumbing as the old one.
No cutting PVC pipe to get this installed.
http://uspartscenter.com/0108-205005.aspx
US Parts Center
Whirlpool Safety... | Answered on May 01, 2014
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Whirlpool Safety... | Answered on Apr 13, 2014
Tell me more about - Wont' start
How do you turn the pump on/off?
Rod
US Parts Center
We locate the seemingly impossible
Whirlpool Safety... | Answered on May 02, 2013
Your motor is shot. you need a new pump. If it comes on and you can hear a hum then it is bad. If you can get us a model number of the pump we can recommend a replacement model for you.
US Parts Center
Whirlpool Safety... | Answered on Apr 23, 2013
Check the circuit breaker and make sure you have power to the pump.
If you have power to the pump and it is not operational when the tub is full of water and you are in it then I would say you have a serious problem.
Most all of the older control that Aquaglass has used in the past have been discontinued.
You may want to visit this link and identify your control before you begin t trouble shoot your system.
Rod
US Parts Center
888-521-6183
Whirlpool Safety... | Answered on Feb 28, 2013
aquaglass has great customer service 731-632-0911
Whirlpool Safety... | Answered on Apr 18, 2011
if your in the north east you would call masco bath at Phone: 856-235-7700
in the midwest you would call Phone: 810-664-8501
in the south Phone: 731-632-0911
and in the west Phone: 800-632-0911 this is the manufacturer and they would be able to provide you with a wiring diagram for your control if you have any further questions message me back Thanks again Rick
Whirlpool Safety... | Answered on Jan 21, 2011
You can go to Lowe's or Home Depot and tell them what you have. They make an epoxy that will fix these holes.
Whirlpool Safety... | Answered on Sep 18, 2010
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Whirlpool Safety... | Answered on Sep 05, 2010
home depot sell a bath tub remodelation kit.
it cost about $40 .
Whirlpool Safety... | Answered on May 19, 2010
This going to be a 3 part solution. You can find all the materials you need a a Boat Supply Store or online. For the first step you will need all purpose filler such as FORMULA 27 ALL PURPOSE FILLER. It comes with hardener, Make sure the area you are working in is well ventilated. Follow the directions and fill inn your hole making sure to not allow it to stick out. Next you will need a Fiberglass repair kit. A kit is the best way to go since it will include everything you need. Again, good ventilation and follow the mixing instructions. You will need sandpaper, medium, fine and super fine (600 grit). If you build iu up to much you can and will need to sand it down. It will not be perfect but you can feather it into the existing area around the hole. Once this cures (hardens) you will be ready to go. The last step is cosmetic, gel coat, this is the shiny surface with the color in it. This step is up to you. It is not needed and can be difficult to match the color.
Good Luck
Whirlpool Safety... | Answered on Mar 25, 2010
You may want to try to find some thin ceramic tile beading and gluing it in place and caulking the remaining gap. Use a waterproof construction glue. This is most likely to be something you customize to fit. Often you can rent a ceramic wet saw and cut tiling to fit the need. Use proper safety gear, and be particularly careful if ripping thin pieces less you gain the nickname stubby.
Whirlpool Safety... | Answered on Mar 23, 2010
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Whirlpool Safety Bath Walk In Bathtub - Stretch Without Logo
37 questions posted
Top Whirlpool Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
View Most Popular
Whirlpool Home
  • Whirlpool Home
Most Popular Question
jets dont work in jetted tub
  • Home
