20 Most Recent
Whirlpool 2 Person Corner Air Tub By Vitabath Bathtubs Questions & Answers
Plastic tubing from pneumatic on/off switch to
These tubes are just pushed on by hand. They are nothing special. If you need to replace them, just use whatever works. Push the ends firmly onto the small stems on the motor and the button. Good luck
Heat
check the reset button near the pump
Is a 300 watt blower sufficient for a 72"x36" air tub?
the blower should be matched to the number of holes and diameter of the hole. there is a pretty precise science to the whole Air Tub product. if the blower is too large it will burn up and if it is too small you won't get the true benefits that an Air Tub offers.
Whirlpool corner tub not working
you wiil need to check 2 things.First you will need to check the motor.Their should be a reset switch on the motor.also attached to the power buuton is ablack thin hose if this hose came off the switch or motor than the motor wont come on.Look around for an access door .If thier is acloset in an adjoining room you might find it thier.
How to clean jet on whirlpool tub
first of all you need to be draining the tub completely and removing any bath mats or items from inside. Fill the tub with hot water, ensuring that the jets are covered. You can use white vinegar, 2-3 cups of white vinegar directly to the water in the tub. Turn on the whirlpool system and run it for 15-20 minutes. While the jets are running, use a soft-bristled brush to scrub the jet openings and the interior walls of the tub. Drain the Tub: Refill the tub with clean water and run the jets again for another 10-15 minutes to rinse out any remaining cleaning solution. This should help. This is what I did with mine
Galbocca tub with jets
You have some bacteria build up on the inside of your tubing of the tub.Try some cleaning solutions per directions on the bottle of tub cleaner made specifically for this situation.
Cleaning Solutions US Parts Center
Galbocca bathtub with jets
I have galbocca jet tub which is no longer working. I live in Lawton, ok. No one works on them here. Any suggestions?
