I looked at the circuit board, but nothing looks fried or disconnected. It doesn't bother me too much, but I like not having to rely on batteries. Any ideas?
Wrong plug
DC adapter won't work, can be due to several causes.
Do you use the original Korg adapter? If using a replacement adapter, make sure the 9 volt DC voltage and current is sufficient. 600mA minimum (1 ampere recomended).
Make sure the replacement adapter also has the correct polarity.
+ at the ring and - at the pin. Also check adapter cable condition.
If the adapter is correct and normal but still can not power ON, then the possibility of damage within the microKORG.
Chances are:
I hope this helps.
Regards.
Found out the problem. The adapter I was using was a - + instead of a + -.
