20 Most Recent Roland Boss RC-2 Loop Station Stompbox Pedal Questions & Answers
Hello - I have a
Make sure the power supply for this is powered from the SAME receptacle as your amplifier is powered. Keep the cable from this to the amp fairly short and high quality cable. Keep guitar away from magnetic field sources... the wall wart adapters are notorious for generating magnetic fields.
7/20/2011 3:11:10 PM • Roland Boss RC-2... • Answered on Jul 20, 2011
Volume knob is broen
The obvious answer is to have it repaired. Sometimes the parts can be hard to find but either DigiKey.com would have the part or you can go to Roland/Boss and order the part. If the knob itself was smashed, the pot also is likely damaged. $5 of parts should fix it up. If you are adept at electronic repair it should be an easy fix.
6/19/2011 5:02:47 AM • Roland Boss RC-2... • Answered on Jun 19, 2011
The Auto on my Boss
Sometimes, with BOSS pedals, the battery must be disconnected before using another power source. I ran into the same problem with my DS-1 distortion. If it's not that, then check the power rating of the power adapter. It should read, for the output, exactly 9V DC. If it doesn't, then you have to get a power adapter that has that same rating. Boss pedals will not use anything other than 9V DC (I know, I've tried).
Hope that helps! Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
3/27/2011 9:57:10 PM • Roland Boss RC-2... • Answered on Mar 27, 2011
My Boss RC-2 Pedal is having a problem with the
Most PROBABLE is the output jack either has been broken (common due to mishandling and accidents with cables such as stepping on the plug while plugged into the pedal) or the soldering of the jack in the pedal has broken loose. Less common is a circuit board crack in the vicinity of the jack. Open pedal and inspect for the above suggestions.
3/11/2011 6:28:36 PM • Roland Boss RC-2... • Answered on Mar 11, 2011
2answers
When I power my Roland D20 up, all I get is bars
Hello. Hello. Generally the upper LCD display of bars is an indication that the internal battery is on it's way out and needs to be replaced.
In case you do not have the owner manuals, they can be downloaded from this address - enjoy: http://soundprogramming.net/manuals/Roland_D-20_Manual.pdf
3/28/2024 1:20:25 PM • Roland Music • Answered on Mar 28, 2024
I have a ROLAND BK5 keyboard instrument that has no sound out of speakers or headphones but it has new ribbon cables all components are working just fine except the sound
I wonder why the ribbon cables have been replaced as they do not fail. Check the keys actuate the contacts properly.
11/1/2023 7:57:00 AM • Roland Music • Answered on Nov 01, 2023
2answers
Damper pedal piano doesn't keep the tone properly
I can't! In my opinion, no. Start drift boss customize your car by choosing different colors and patterns.
10/31/2023 1:49:23 PM • Roland Music • Answered on Oct 31, 2023
ROLAND G70 . I HAVE LOST THE VISUAL OF THE MIDI
4/17/2023 4:19:13 PM • Roland Music • Answered on Apr 17, 2023
2answers
My Roland FP4 piano has suddenly ceased to power on. Is this fixable?
most likely we dont have crystal balls --need to have diagnosed for problem
4/10/2023 12:49:18 PM • Roland Music • Answered on Apr 10, 2023
Hi. Can I use the second pedal on my Roland BK5 to scale up the key one semitone at a time?
Yes, you can use the second pedal on a Roland BK-5 keyboard to transpose the key of the music that you are playing up or down by a semitone at a time. To do this, you will need to press and hold the second pedal while playing the keyboard. You can also use the transpose function in the settings menu of the BK-5 to adjust the key of the music that you are playing by a specific number of semitones.
1/5/2023 4:04:49 PM • Roland Music • Answered on Jan 05, 2023
Roland cube 80XL, making weird sound when it's on, nothing is plugged in, all controls down to 0
I am also using IOS and Android. So how can I improve some features? The black screen helps you relax when using the computer too much.
12/22/2022 6:43:06 AM • Roland Music • Answered on Dec 22, 2022
Roland Octapad SPD-30 dead.
Question edited for a bit more clarity. Video that might help https://www.google.com/search?q=Roland+octapad+spd30+dead Owners Manuals only. https://www.google.com/search?q=roland+octapad+spd30+service+manual ..
12/19/2022 1:50:50 AM • Roland Music • Answered on Dec 19, 2022
2answers
I need a circuit diagram for a Roland MA-15D speaker please?
It's a Chinese made Roland and no service information is available as when a fault is found the main board is replaced, eliminating the need for service information. I would check that it is a stereo out jack and not mono. If it is a stereo out, check that both input phonos work. If they do, replace the faulty socket or damaged pcboard.
11/17/2022 6:14:26 PM • Roland Music • Answered on Nov 17, 2022
Roland Boss RC-2 Loop Station Stompbox Pedal Logo
Popular Tags
10 questions posted
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
View Most Popular
Roland Music
  • Roland Music
Most Popular Question
hello i have a
  • Music
