20 Most Recent Alesis Sr 16 Stereo Drum Machine Questions & Answers
Yamaha Electone HS8 powers up but no sound. I
Hello has you for repair this orgel ? i have th? same probl?me
10/19/2021 7:46:21 AM • Alesis Sr 16... • Answered on Oct 19, 2021
How to change internal battery in alesis d4 drum module
I replaced the internal battery and since I couldn't find a battery holder, I added 3 wire posts to the board, so next time I won't have to remove the whole board, simply unsolder from above. Simple hack.
1/30/2021 1:24:09 PM • Alesis Sr 16... • Answered on Jan 30, 2021
Does the alesis sr 16 have a back light on the screen
yes, it should light up when you turn it on. Make sure you have the right adaptor. The voltage & polarity will be wreitten on the unit. My adaptor is from Alesis. You can find these on ebay.
9/23/2020 4:04:59 AM • Alesis Sr 16... • Answered on Sep 23, 2020
I get a loud crack sound when I switch on the drum
That would be normal - the order you power up equipment is very important. Always start with peripherals and work toward the power amp. Powering off is reverse - power amp first. You can also mute the mixer channel you're plugged into before powering up the drum machine but get into the habit of proper power sequence.
1/9/2019 11:46:15 AM • Alesis Sr 16... • Answered on Jan 09, 2019
I recently bought two Alesis Quadrasynth Plus
Assuming you've tried rebooting the white screen one? If so, You need to take both to a qualified repair man and get the job done right. If you start swapping parts without knowing what works and what doesn't, you risk screwing up the good parts,
5/18/2017 2:44:28 AM • Alesis Sr 16... • Answered on May 18, 2017
It wont play thru my amp only headphones and no demos or preset patterns
Re-initalize the machine. If that doesn't work, it's time to take it to the shop. However, replaceing it may be more cost effective.
8/20/2015 12:33:44 AM • Alesis Sr 16... • Answered on Aug 20, 2015
Drum machine working ok then suddenly cut out, disconnected power supply then an acrid smell of burning came from the machine.
In my case, a -15 volt trace runs under the 1/4 inch connectors and right at the edge of the circuit board. I think slight movement of the connector wears that trace out and in my case it caused it to short to a nearby trace. I ran a 30 guage wire in its place to fix it. Also see https://www.youtube.com/watch?v=6RJVtQ8i0eY
5/5/2015 9:51:17 PM • Alesis Sr 16... • Answered on May 05, 2015
2answers
How do I reinstall preset patterns
According to the Alesis SR16 Frequently Asked Question section: Power On while holding down Erase and Play. http://alesis.com/sr16
4/25/2015 12:34:41 PM • Alesis Sr 16... • Answered on Apr 25, 2015
I would like to know the code about the C5 condenser behind the catch of the power supply unit about the board mother. mine is roasted. Thank you
2200mfd / 16volt Make sure there are no other problems before you replace it! It does not get barbequed by itself. Have Fun.
4/9/2015 12:58:58 AM • Alesis Sr 16... • Answered on Apr 09, 2015
Hello I recompose my question. J would like to know the value of the ceramic condenser close to connector VAC of the circuit of Sr-16. On the circuit C5 opposite the condenser is written. it is round
You might try going to this webpage https://www.alesis.com/sr16 and from the docs&downloads section download and search the Reference manual. It's also here http://www.burnkit2600.com/manuals/ALESIS_SR-16_OM.pdf (this looks more like a user guide though) Failing that, choose 'support' from the th top of the page and either contact Alesis support or else ask your question in the 'community' (which you will have to join). Another community which deems to have an interest in the SR-16 is www.circuitbenders.co.uk but I think it unlikely that they could direct you to a circuit diagram, though it is slight possibility that someone might know the value of the capacitor C5 23.December.2014
12/24/2014 12:11:41 PM • Alesis Sr 16... • Answered on Dec 24, 2014
ALESIS SR-16 won't save patterns
Really Quick. Two problems are unrelated. Assume older unit. Needs memory battery, and new display.
11/9/2014 12:21:05 AM • Alesis Sr 16... • Answered on Nov 09, 2014
2answers
Scratchy volume potentiometer
Try cleaning your volume potentiomenter with contact cleaner (they come in spray can's), the scratchy sound is audible when you turn your volume control on, the contacts inside your potentiometer accumulated dust or some other particles.
10/3/2014 6:57:08 PM • Alesis Sr 16... • Answered on Oct 03, 2014
How to program drum beats from one alesis sr16to another alesis sr16 drum machines
5.4J Copy a Song to Another SR-16 Via MIDI The SR-16 can send Song system exclusive information to another SR-16 via MIDI. If you have only one SR-16, you can skip this section. 1. The source SR-16 should be in Song mode and stopped. Connect the source SR-16 MIDI out to the destination SR-16 MIDI in. 2. Select the Song to be copied. 3. Press and hold the COPY button, and keep holding it down until step (5). The display says COPY TO SONG. 4. Do not enter any destination Song number-just press PLAY to send the data out over MIDI. It will end up in whatever Song number had been selected at the receiver. If the Song was not empty, the new Song steps will be appended to the existing Song steps. 5. Release the COPY and PLAY buttons. Caution: This does not transfer Pattern information, only the song steps. To transfer Patterns to another SR-16, see section 3.3D and 3.3E. Hopefully this helps, it comes out of the SR16 Manual, page 40 I think Cheers Pete
9/29/2014 3:58:17 AM • Alesis Sr 16... • Answered on Sep 29, 2014
Alesis sr 16 service manual
I got a service manual but don't know how to get it to you. I can sent it by email. Let me hear from you. Contact: [email protected] (subject: "Manual") The manual is for Alesis HR-16B SRV comes in PDF format.
8/31/2014 7:50:48 PM • Alesis Sr 16... • Answered on Aug 31, 2014
Alesis Sr 16 Stereo Drum Machine Logo
176 questions posted
Top Alesis Music Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Aron
Are you an Alesis Music Expert? Answer questions, earn points and help others
View Most Popular
Alesis Music
  • Alesis Music
Most Popular Question
  • Music
