20 Most Recent
Korg Micro Microkorg Xl Synthesizer Vocoder Keyboard Bk Questions & Answers
I have a Korg Microkorg
The volume control must be have dirt in it. When you move it do you hear rustling noise. A quick spray of WD40 spray into the control will solve the problem.
Korg Microkorg XL Vocoder Not Working (No Sound)
Check the mic and connections all through its input into the unit. I would check the cartridge of the mic for continuity for the reason that (I think but not 100% sure) on this model, I think there has to be sound at the mic or it does go silent in vocode mode. This is how it digitizes the mic and keys together. The played keys cannot put onto pitch the sound it is NOT picking up at the mic. I think there is a problem with the mic.
Hello everyone. The dial on my microkorgXL which
Sounds like a bad rotary encoder (the part that the "dial" is attached to"). If the circuit board or solder is not cracked in that area then that is likely the problem. You could find the part at mouser.com (about $1) and would need desolder the bad encoder and solder the new one in place or get the whole PCBA(printed circuit board assembly) from Korg.
I have a korg n1 and when I turn it on the display screen comes on but no words show up on it I was wondering how to fix it
It sounds like your ROM battery, which the ROM contains and stores the patches for the keyboard, has gone completely dead and your keyboard is dead in the water. However, if you can get a MIDI to USB converter and get the battery changed, then you can reload the patches back onto the keyboard.
I have worked on a Korg M1 Workstation and have had to replace the battery(CR2032) and then had to run a program called "MIDI-OX" which also gave me access to the patches needed in order to restore the keyboard to factory patch settings.
http://www.midiox.com/
Take a look at this AFTER you have gotten the battery replaced. I will tell you that replacing most batteries is a very intricate job as, the bottom of the keyboard has to be removed, as well as a lot of the internal boards. I had to draw a diagram and mark certain pieces so I would know where they went and in what order they have to be re-attached. My advice is take it to someone who works on electronics unless you want to DIY (not recommended) to get the battery replaced.
Hope this helps.
3/8/2022 8:37:05 PM •
Korg Music
Answered
on Mar 08, 2022
