The power button does nothing on the camera. I have tried new batteries, as well as the original. All were fully charged when testing.
SOURCE: Canon PowerShot S45 Digital Camera
Maybe this fuse is blown:
http://www.hit-karlsruhe.de/aol2mime/images/S45_S50_PowerFuse.jpg
Short it or replace it.
See also http://www.hit-karlsruhe.de/aol2mime/canon_powershot.htm
SOURCE: Camera won't power up
Mine was the microswitch that tells the camera the battery / card door is closed. The tiny, cheap plastic protrusion that pushes on the switch broke off. Jam the switch with the end of a toothpick.
SOURCE: Camera will not turn on. Battery fully charged;
You can give it to an expert for repair, he can repair it for less as there must be just a fuse problem, which can be fixed for a very less amount.
SOURCE: Canon 40d-pressing the shutter seems to short out the camera.
I recommend that you remove both batteries for ten minutes to get a full reset. you spoke of the main battery. When you open the battery compartment, look at the lower right toward the camera with the LCD facing you.
It is a little hard to see, but will say CR2016 3V. Stick your fingernail under the lip and just pull it out.
As I said I left both batteries out for about 10 minutes.
You will have to re-set the date and time after your done.
SOURCE: canon sd1000 camera won't turn on. battery is fully charged.
Make sure or Check out following thing :-
Else, Your device need service (repair)
Rating the solution is highly appreciated....Good Luck
