Canon PowerShot S2 IS Digital Camera Logo
Loretta Allen Posted on Jun 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Keep getting error on sd card - Canon PowerShot S2 IS Digital Camera
Huseyin Huseyin
Level 3:
  • Canon Master 3,469 Answers
  • Posted on Jun 17, 2015
Huseyin Huseyin
Canon Master
Level 3:
Answers
3469
Questions
Helped
767117
Points
11197
Hi, if the card has never worked in that device before you should probably check they are compatible.
Some cameras will only take an SD card of a certain size. Some will only take SDHC but not SDXC. Check the spec of your card, is it the correct class, etc...that may throw up a resolution to your issue
GOOD LUCK
AVIC-F700BT FIRMWARE ERROR CODE
Download frsh firmware from manufacturer, yours may be corrupt and use a NEW sd card, they do develop faults every now and then
Memory card error
Make sure you're using SD cards. If the cards are larger than 2GB then they're actually SDHC cards. While they fit in the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
1helpful
I keep getting a Card Access Error message on my Sharp VE-CG40U, what could be causing this?
Actually, you didn't. You put in a new 4GB SDHC card. The camcorder works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
SD CARD ERROR
Have you formatted the CD card to the correct format? Check the manual to see what formats the CDJ1000 will read. I am sure that some won't work.
My camera won't accept new 2GB SD card. Keep
Do you have pics on the internal memory? You must format the internal memory with no card in the camera. Then, format the card.
I keep getting the error msg memory card cannont be read
Your camera is only supporting: SD/MMC up to 1 Gigabyte
The card that you currently have might be high speed. All should be sorted if you change the SD card to the supported MMC SD card up to 1G. There is a lever on the SD card this one might need to be changed.
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
I Keep getting "playback error" "format not supported" on lgcf360
Hello All, I think I may have a solution for the 'Playback Error'problem with the LG CF360. Below, I have put the steps that caused my phone tohave the error and then the steps I took to get rid of the error. Firstly, my CF 360 worked well for hours of playing songswithout any error. Then, after I did the following steps, the error happenedover and over.
  • I pushed a mp3 ring tone via blue tooth to the phone with the SD card in. It saved the ring tone in the SD card, but I wanted it on the phone in case the card was out, it would still ring.
  • I took out the SD card and pushed the same file to the phone, so it would save on the phone and not the SD card.
  • I also pushed another mp3 to the phone.
Then, the "Playback error" happened intermittently every fewminutes. This may have been caused by either
  1. The phone's library of mp3's being corrupted because of the same file in two locations, or
  2. The phone's physical memory getting too low to effectively play music.
Here are the steps I took that got rid of the error.
  • Delete the duplicate mp3 from the SD card
  • Move all music mp3's to the SD card and off of the phone.
  • Move some pictures to the SD and off of the phone.
  • Shut off phone
  • Take out SD card.
  • Turn on phone and try to play a playlist of songs that were on the SD card (causes the phone not find the file and update the music library)
  • Put in SD card while the phone is on. (causes the phone to re-build the music library).
After I did this, I have played mp3's for hours without anyerrors at all, just like before. Either I had too much stuff on the phone orthe music library was not correct causing the crash. I hope it helps. Mike
3helpful
Polaroid i733 card error
The i733 works with SD cards. Your 8GB card is actually an SDHC card. While it fits into the slot, it won't work. You need to go with SD cards, 2GB and smaller.
I/O device error with 16GB SD on XP
i have aproblem of virus which virus software is best for my computer please send virus name
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
