20 Most Recent Polaroid i733LP Digital Camera Questions & Answers
Sorry - why is it a problem ? Are the photos OK ? If so, don't worry
Polaroid i733LP... | Answered on Jun 11, 2017
You don't need a driver.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Polaroid i733LP... | Answered on Dec 10, 2013
If you are using a memory card, take no more pics until you've recovered the photos, take the card out of the camera. This is to reduce the chance of you overwriting some of your "lost" photos. There are many good freeware photo recovery software options that are available to help you recover your photos. This blog article reviews and outlines several of the better ones.
Polaroid i733LP... | Answered on Nov 12, 2013
Well, there is no recycle bin function with your digital camera. Even though you deleted the photo while the camera is connected to your computer, it won't also go to the Recycle Bin or Trash. But that doesn't mean you have lost the photo permanently. Take a try this digital photo recovery software as soon as possible. If you are running Mac machine, go to photo recovery for Mac.
Note: DO NOT take more photos with the same camera from now on before it is recovered. Best regards.
Polaroid i733LP... | Answered on Nov 11, 2013
try to change the battery
Polaroid i733LP... | Answered on Sep 21, 2013
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Polaroid i733LP... | Answered on Nov 19, 2012
me too i need the software not the driver
Polaroid i733LP... | Answered on Jun 10, 2012
Format the memory card. This erases everything from the card and prepares it for further use.
You may download a copy of the manual here.
Polaroid i733LP... | Answered on Mar 05, 2012
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Polaroid i733LP... | Answered on Dec 24, 2011
Consider NOT using a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa.
Polaroid i733LP... | Answered on Oct 08, 2011
Hello
Copy all the pictures from your digital camera to your computer, then format the SD card using your camera. File error is usually caused by editing the files in the SD card using your computer, then when you view it on the camera, you will get the error.
Polaroid i733LP... | Answered on Sep 06, 2011
my camera has 07 the year want to change it to 2011
Polaroid i733LP... | Answered on Aug 17, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
Polaroid i733LP... | Answered on Aug 09, 2011
This is a camera system failure and includes the lens, not cost effective for repair, cheaper to replace.
Polaroid i733LP... | Answered on May 15, 2011
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Polaroid i733LP... | Answered on Apr 25, 2011
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Polaroid i733LP... | Answered on Apr 22, 2011
Polaroid i733LP Digital Camera Logo
201 questions posted
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
View Most Popular
I Polaroid
  • I Polaroid
Most Popular Question
finding deleted photo
  • Cameras
