Steps to Fix Error Code 36 on Apple Mac OS X
For Other Technical error Dial Apple Mac Support Number 1800-582-2431
How Mac Error Code 36 Occur?
While copying the files from your Mac system you may spot error with code 36 stopping your Mac OS X finder process. Actually, the error code represents "The Finder can't complete the operation because some data in FileName can't read or written. To Fix Mac Error Code 36, just read the easy steps are given below.
Steps to Fix Mac Error Code 36:
Step 1: The first thing you need to do is launch the terminal and to launch this you need to follow the path Applications/Utilities/ or with Spotlight.
Step 2: At commandprompt you need to type "dot_clean /Path/To/Directory/With/Problem/" and if you need any help, call to Mac technical support.
Step 3: When dot_clean is finished, now try the file copy again and possibly fix error code 36 Mac OS X without facing any other issue.
Step 4: The error code may appear on any Mac computer device except the symptoms that may differ due to configuration of the computer.
Step 5: If the problem persists especially while copying the file from a Mac network share through external drive some sort, or to and from a windows computer.
Step 6: Delete all .DS_Store files on a Mac using the command line that works temporary workaround if for some reason dot_clean fails. 1 833 493 0111 How to Fix Mac Error Code 36 on Mac OS
Check this video out.
Error code 36 How to fix Mac Error Code 36
