20 Most Recent Brother MFC 6490CW InkJet Printer Questions & Answers
i have brother dcp 6690cw and it said unable clean 46 i want solution for this
thank you so much
Brother MFC... | Answered 18 hours ago
5A-Reinigungsfehler:
Bei mir war es der ?bervolle Tintenschwamm.
Den vollen Schwammbeh?lter habe ich mit Saugt?chern gereinigt.
Danach kein Fehler mehr.
Brother MFC... | Answered on Dec 13, 2018
Procedure1: Changing the LCD Contrast setting
  1. Press Menu.
  2. Press the Up or Down Arrow key to choose General Setup.
  3. Press OK. (For touchscreen models, skip this step.)
  4. Press the Up or Down Arrow key to choose LCD Settings.
  5. Press OK. (For touchscreen models, skip this step.)
  6. Choose LCD Contrast and then choose Light, Med, or Dark.
  7. Press OK. (For touchscreen models, skip this step.)
  8. Press Stop/Exit.
Procedure 2: Changing the Backlight Brightness setting
(This option may not appear depending on the model of your Brother machine.)
  1. Press Menu.
  6. Choose Backlight.
  7. Do one of the following (The menu varies on your model.):
    • Choose Light, Med, or Dark.
    • Press the Left Arrow key to make the backlight darker or press the Right Arrow key to make the backlight lighter.
  8. Press OK. (For touch screen models, skip this step.)
  9. Press Stop/Exit.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Brother MFC... | Answered on Nov 29, 2017
Plug your computer to the printer via USB cable, then turn off the printer... and turn it back on again, short term fix but works for me ...
Good luck
Brother MFC... | Answered on Nov 23, 2017
Did you ever resolve issue with broken tab. I have same problem on my black cartridge release tab, and am wondering if I can need tab or can salvage. Thanks!
Brother MFC... | Answered on Sep 27, 2017
my brother MFC-6490CW keeps coming up with an error message 'cannot print 70' how do i solve this?
Brother MFC... | Answered on Aug 19, 2017
Power down your printer to clear the cache and re load from page 3.
Brother MFC... | Answered on Jun 20, 2017
If it's under warranty you're in luck, you need a new printhead,LK3197001, around $80.00. I just replaced one yesterday in the shop for the same problem. I would call Brother customer service and see if they'll help cover the cost.
1-800-276-7746
Brother MFC... | Answered on Mar 27, 2017
I have had to take mine apart too. Nothing wrong with copy inks. If you can not be helpful dont bother doing an 'I told you so' you are not helping anyone just gloating at your snob values
Brother MFC... | Answered on Jul 03, 2016
Brother MFC 6490CW InkJet Printer print alignment
Brother MFC... | Answered on Jul 02, 2016
This is a possible printhead problem. Call brother may times they will do it was a warranty repair even after the warranty period.
Brother MFC... | Answered on May 20, 2016
Brother MFC 6490CW InkJet Printer Logo
541 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
unable cleane 50
  • Office Equipment & Supplies
