20 Most Recent
Brother MFC-465CN InkJet Printer Questions & Answers
My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
5/12/2016 7:37:43 PM •
Brother...
Answered
on May 12, 2016
Brother mfc465-cn unable to init 49
Error 49 relates to the print head drive voltage. It may just need the flat ribbon cables that connect the head to the main pcb reseating, but equally it may need the print head replacing (most likely).
An outside chance that the main pcb will need replacing.
In theory, all of these jobs are a task for an engineer. Brother UK (0870 830 400) can pass you on to a repair agent.
4/2/2015 8:47:03 AM •
Brother...
Answered
on Apr 02, 2015
My printer will not do anything
most ink jet printers are not made for any type of volume of more than a couple copies a day. my advise would be to donate this one and purchase a LASER jet printer. the cost to fix this is more than what it is worth.
1/5/2015 5:58:04 AM •
Brother...
Answered
on Jan 05, 2015
How do I fix double printing
Not sure what you mean by double printing.
Is it printing a ghost of what you print further down the page. Or is it mis-aligning the characters so it appears to have a shadow on each character?
8/20/2014 3:20:23 AM •
Brother...
Answered
on Aug 20, 2014
No cartridge error message
I just had the same problem. Turn the printer off and back on again. It will reset itself.
Cheers!
TJ
7/27/2014 8:15:22 PM •
Brother...
Answered
on Jul 27, 2014
How can I fix no cartridge error on brother mfc-465cn
It sounds like it may actually be the "print head" which is what the carts fit into. These can and will go bad. Sometimes you can find replacements on ebay etc. But you need to make sure it is exactly the same part number. There could also be a number of other issues, the cart contacts could be dirty or damaged (another print head issue resolved by replacing), counterfeit cartridge, bad cart. These are the most common, but not the ONLY issues that can cause your problems. I'd check prices for replacement print head vs. new printer.
7/18/2014 4:24:19 PM •
Brother...
Answered
on Jul 18, 2014
