Washing Machines Logo
b
ben newlands Posted on Mar 31, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motor wont start
Machine fills with water then drains and proceeds to S.Have replaced the worn brushes but no joy still doing the same proceeds to s
  • 1 more comment
  • ben newlands
    ben newlands Apr 01, 2015
    Hi Jhonny does not appear to be anything you sugested to clarify turn machine on temperature at o degrees turn knob to any desired wash program (have tried them all) machine starts fills with water pauses then pumps out water and proceeds to the S on the program knob.Whilst in this position a dull sort knock appears to be comming from the motor or pump ?solenoid
  • Jorgie  the appliance guy
    are u sure its from the motor area? the pumo can also make a noise if it is obstructed but u say it is draining? so therefore THE DRIVE MOTOR- If the washer is making a loud noise the drive motor bearings may have worn out. Washer motors are normally almost silent when they run. If the motor is run without a belt hooked up to it and it's loud it will have to be replaced
    If your washer has a loud banging noise during spin the balance weight may be loose. This weight is to counter act the weight of the motor so you will find the weight directly behind the motor. Sometimes simply tightening the bolts will fix your issue but if the bolts are stripped out get some bolts slightly longer than the original bolt to allow you to put a locking nut on the bottom side of the mounting plate. If the weight is broken replace it.
Level 3:
Top Expert:
  • Asko Master 5,639 Answers
  • Posted on Mar 31, 2015
Asko Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523901
Points
32630
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more. Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine. Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Wpre6100g1wt
there are two possible reasons
1 belt has come off the drum and motor
2 the brushes in the motor have worn down so far that it wont turn.
did it happen all of a sudden, or over did it get worse over a period of time?
2answers
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
2answers
Water control valve washer
Hi carl if your Beko WM5140W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
2answers
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Washing machine makes clicking noise after filling up and wont spin. Kepps on clicking until i force shutdown, which then drains the water away.
hi, the problem you have is the motor carbons (brushes) have worn down ( which is natural if machine is used every day ). the machine fills up with water but there is no motor action. the clicking noise you are hearing is the relay on the pcb sending a signal to the motor to turn, but with the carbons worn, there is no motor action. Easy enough to replace them. UNPLUG machine before any repairs are carried out.
GE washer wont agitate or spin ?
This could be because the carbon brushes in your motor are worn down. One will need to check the motor to be sure.
The carbon brushes apply electricity to the motor via a split ring comutator.
Over a while the carbon dust can create a short circuit. The motor needs to be looked at and cleaned. Possibly may need to replace the brushes.
Take care!
damnor01
MY WASHING MACHINE WONT START WASHING
Could be motor brushes or the motor....
1helpful
WFD 2460 will not start wash cycle after it has filled with water
Isolate power and water supply and gain access to the main drum motor. Check for condition of carbon brushes by removing them and repla
ce if severely worn. Check wiring loom around motor and right back to module controller. The clicking is obviously power being supplied to motor via the loom to the motor. finally check for any dry solder joints or burnt areas on the circuit board controlling the motor.
Asko 620 not spinning and not agitating
Clean armature and replace brushes. When you remove the brushes the shut a small pin like device maybe protruding from the brush tip. this is a sure clue.
Jun 18, 2008 • Asko W620
Mrs E King
sounds like worn motor brushes if it fills drains heats etc but no drum action brushes need replacing not expensive job if machine over 3 years old or older almost certainly brushes.
Top Asko Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
