20 Most Recent Asko W600 Questions & Answers
Can you call an expert to figure this out so we can help you with this
Asko W600 | Answered on Mar 14, 2016
ITS NOT SUPPOSE TO HEAT UP THE WATER COMES IN HOT FROM THE OUTLET? THE WATER TEMPERATURE SWITCH DETERMINES WEATHER IT USES HOT OF COLD ECT
Asko W600 | Answered on Apr 03, 2015
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
No agitation or spin? try these:
Washer fills with water then drains:
The critical question is. Is the water is just running down the drain but the pump isn't running. If it is being pumped out, and you can hear the pump running just the same as when it's emptying prior to spin then it could be aborting the wash because it is, or it thinks it's overheating. ( due to defective water temperature switch)
If water isn't being pumped out, but just draining away all the time, the washer will keep detecting there isn't enough water inside and top up with more. Modern washing machines should be sophisticated enough to realize something's wrong and abort with an error, but if not, it may continue washing or rinsing for a short while before losing enough water to trigger more coming in again. It can get stuck on this cycle indefinitely and it's called siphoning.
Siphoning occurs when the end of the drain hose is lower than the level of the water inside the washing machine. Try raising the hose and see what happens.
Also the drain hose should have some type of air gap where it fits into the stand pipe. It should not have an air tight fit.
Other switch's to check would be the water inlet valve and the water pressure switch with a multi meter for continuity or OHMS.
Asko W600 | Answered on Apr 02, 2015
some can be taken apart and inside is a spring loaded connection that pushes the button back out sometimes hard water and soap and debris can jam and stick the spring and u get what ur getting? you may be able to by pass the extra rinse by disconnection the prongs to it and taping them up?
Asko W600 | Answered on Mar 30, 2015
Sounds like your circuit board has a problem. go to www.repairclinic.com. Look up washing machines and enter your model number, then a list of parts show up, they have a trouble shooting column. They have videos and the parts you will need.
Asko W600 | Answered on Mar 10, 2015
locate the filter and clean, this should cure
Asko W600 | Answered on Apr 17, 2014
Check to see if your model has a "out of balance" micro switch.
If it's tripped from you moving the unit around you may have to reset it manually. It will be mounted somewhere close to the outer perimeter of the tub. Can't say exactly where. Could be high or low.
Asko W600 | Answered on Jul 11, 2012
clear filter at pump
Asko W600 | Answered on Jun 28, 2012
Hello Greg, welcome to FixYa.
To address your post of the washer not spinning and your curiosity of a faulty pump...the pump may simply be obstructed preventing a proper drain, thus a compromised spin, they are directly related. These frontloaders will not spin until they drain sufficiently. (though a faulty drain pump is possible, it woud be the exception, not the rule).
There is typically a drain filter in the pump as you may or may not know, based on your description it may be clogged. You'll need to access it, clean it out via draining it through the pump "emergency drain hose" before you can in the end open the door (though usually once drained to a safe level it will open under normal procedures) however there should be a door lock release on Asko built machines...including the W600 series.
This is the procedure for machines of the past 10yrs. or so...(this is only an example, it may not be exact but essentially the same as yours)
Hopefully this will help. Let me know if anything is unclear or If I can assist you going forward. Thank you for choosing FixYa and good luck going forward.
Regards,
Macmarkus :)
Asko W600 | Answered on Nov 21, 2011
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Asko W600 | Answered on Sep 15, 2011
Washing Machines Logo
49 questions posted
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Joseph Hoffmann
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Asko Washing Machines
Most Popular Question
machine normal wash starts ok but get
  • Washing Machines
