20 Most Recent Bosch Logixx WFT 2806 Front Load Washer/Dryer Questions & Answers
Open the small flap at the front bottom right of the machine. DONT unscrew the circular white knob yet!!! Use the small black hose to drain the machine into a tray, by removing the small cap on the end of the hose. You will have to use a tray, rather than a bowl because the hose is only short, and keep emptying the tray.(put a washing up bowl next to the machine, so you don't have to carry the tray.) If water does not come out of the hose, then gently unblock it with a piece of wire or fine knitting needle. When water finally stops coming out of the hose, it is time to gently unscrew the white knob anti-clockwise, and pull it forwards. Now you can clear the debris out of the pump rotor, which is behind the white knob. Check with your finger that it can rotate freely, then replace the white knob firmly. Make sure the small cap is replaced on the end of the hose, clip it back into place and put back the cover panel. If this doesn't work then there is a blockage deeper in the machine, and dismantling will be required. Good Luck!!
Bosch Logixx WFT... | Answered on Dec 27, 2018
My Bosch washing machine shows error code F57 and beeps
Bosch Logixx WFT... | Answered on Dec 13, 2018
Bosch Logixx 8 error code nr0 means - The childproof lock has been activated.
Just deactivate the childproof lock.
Bosch Logixx WFT... | Answered on Mar 23, 2018
The door is not locked properly.
Open and close the door again and press the "start reload" button (play and pause button). If necessary, open the washing machine door, remove some of the cothing items and then push the door closed again. You can also try switching the washing machine off and on again, setting the programme and then starting the programme.
Bosch Logix with error code F43 has "a motor fault".
You can reset the error code by the follow steps:
1. Turn the appliance knob to the off or reset position, 12 o'clock.
2. Turn the knob to the 6 o'clock position.
3. Press and hold the spin button and while holding the spin button turn the knob to the 7 o'clock position. Continue holding the spin button for about 5 seconds then release the spin button and now turn the knob to off
When your turn it back on it should have cleared the error code
Check motor connector block
Check wiring
Check motor carbon brushes
Check tacho connections
Check motor
I would call the local engineer for a quote as the heating element ma need to be replaced eric
Bosch Logixx WFT... | Answered on Jan 17, 2018
this has just happened to my Bosch, means the base pan is leaking water...I've had 4 problems with mine in the past and WILL NOT BUY BOSCH AGAIN, poor customer service too.
Bosch Logixx WFT... | Answered on Jan 13, 2018
Sump hose has fallen off Unplug tilt machine back have a look underside to check also could be the soap dispenser hose Hole in it.This rubs away on side of machine 5yrs old.
Bosch Logixx WFT... | Answered on Sep 13, 2017
Plane on fire eject eject eject
Bosch Logixx WFT... | Answered on Aug 05, 2017
F37 is because of operating the unit below specified temperatures.
Pressing the temperature button twice shows a snowflake and sets a defrost function.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Bosch Logixx WFT... | Answered on Jan 23, 2017
F23 that it indicates a leak into the base of the appliance.
You'll need to unplug the appliance and take the rear cover off.
Check for a spillage and if there is an anti flood device in the base, ensure it's reset/working or replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
Bosch Logixx WFT... | Answered on Jul 09, 2016
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
it means the float at the base of the machine has been triggered. Open the back panel on the machine (turn off power and water tap first) then remove all screws and take metallic back off. Dry inside base with a towel and push down the float which is located in the corner. This will reset it. Keep an eye on it as it may mean you have a leak.
Bosch Logixx WFT... | Answered on Mar 27, 2016
The child lock on my Bosch Logixx8 washer has come on and i need to disable it
Bosch Logixx WFT... | Answered on Mar 04, 2016
Turn it anticlockwise
if it won't turn it has something inside jamming it
you will need to remove the pump and filter assembly and take it apart to clear it
Bosch Logixx WFT... | Answered on Jul 12, 2015
Bosch Logixx WFT 2806 Front Load Washer/Dryer Logo
222 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
fault f18 error code bosch washing
  • Washing Machines
