20 Most Recent Beko Wm & Wma Models Washing Machine Motor Carbon Brushes Questions & Answers
Blown fuse but appliance still works
There may be a short AROUND the fuse. Kinda rare but it does happen.
11/22/2017 3:35:05 PM • Beko Wm & Wma... • Answered on Nov 22, 2017
Put 40 cotton cycle on starts taking water then stops
The leak has to be fixed
1/10/2016 12:53:23 AM • Beko Wm & Wma... • Answered on Jan 10, 2016
Forty cycle takes some water in then stops
Beko WM5100W Washing machine wash/spin problem ...
? 3:59 https://www.youtube.com/watch?v=rih6H1cpu9Q Jun 12, 2012 - Uploaded by ilona ilona problem in washing cycle. fast spin for few seconds and cut off .... I have same machine, it starts up fills half way with water then stops :'.
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
1/10/2016 12:52:13 AM • Beko Wm & Wma... • Answered on Jan 10, 2016
Beko wm5120w starts to spin then stops?
check pump for blockage
4/30/2015 7:31:19 PM • Beko Wm & Wma... • Answered on Apr 30, 2015
2answers
My washing machine wont spin
Hi if your Beko Wm & Wma Models washing machine wont drain or has a spin problem then you have to check the carbon brushes first. Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below How to replace Beko Washing Machine Motor Carbon Brushes you might find this test video helpful but only do it if you have checked the motor
2/14/2015 6:25:28 PM • Beko Wm & Wma... • Answered on Feb 14, 2015
Water leaks out of the washing powder compartment
it might from closing the powder drawer not completely and correctly or having crack in the drawer or having the high water pressure in the Water pipeline network check all above , if not , call service center thank you
11/22/2014 8:01:57 PM • Beko Wm & Wma... • Answered on Nov 22, 2014
I have beko 91442 lx and can get it to start. All lights etc on. Thought it might be child lock but can seem to get it on or off. What can I do please
i think it refers to elec-card 1- first unplug the machine for about 10 min 2- plug the machine and start short program if led are on please specifies which led are lighting !! thank you
11/22/2014 7:54:46 PM • Beko Wm & Wma... • Answered on Nov 22, 2014
THE MACHINE FILLS WITH WATER BUT WILL NOT GO THROUGH A CYCLE
and also this one may help
11/1/2014 10:54:37 AM • Beko Wm & Wma... • Answered on Nov 01, 2014
I need beko aa class 1000rpm operating manual
Hi Edwin, good day! For that specific brand and model, you can actually check this link for the file and download it from there: Beko Automatic Washing Machine Installation Operating Instructions...
9/22/2014 7:13:32 PM • Beko Wm & Wma... • Answered on Sep 22, 2014
Is there a filter
Usually you can remove the kick strip by putting a small screwdriver in the gap and levering the panel off to find the pump filter behind
7/29/2014 6:02:28 AM • Beko Wm & Wma... • Answered on Jul 29, 2014
How to reset beko wm5120w washing machine
You need to get the dial to 90 degree program then push the start and on button together. Keep hold the start button then a light will flash. Then move the dial to spin/drain option and press start to start the reset test mode. Hope this helps.
6/8/2014 7:09:15 PM • Beko Wm & Wma... • Answered on Jun 08, 2014
Beko wmb81445lw
Where does it get to before stopping or what is it doing or not
1/10/2014 9:48:03 AM • Beko Wm & Wma... • Answered on Jan 10, 2014
Beko dishwasher drain din16210
The pipe or filter may be clogged. To check this, pour clean water through the drain. If it is clogged, use a plunger to drain the objects causing the blockage, if you are unable to successfully remove them, seek help from a plumber.
11/5/2023 3:20:27 PM • Beko Washing... • Answered on Nov 05, 2023
Fault on my Beko WMB 61431 W. Ready light flashing and programme stalls?
Check the water pump alongside the filter housing for foreign objects.
8/6/2023 10:14:11 AM • Beko Washing... • Answered on Aug 06, 2023
Why won't the washing machine start when I press the START/Pause/CANCEL BUTTON/
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on. The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in Door switch if bad can be jumpered with a bypass, fisrt check with meter for ohms. Or open line cirrcuit this switch can hinder or stop operation, agitation or spin cycle. Also check washer fuse usually located along the drum tub or inside control panel. Some type washers may have a motor switch that my have been tripped. Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings. By the way my advice is free cuz God is good! All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced Lastly CONTROL BOARD If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures. door switch jumper-undefined-undefined-0_2.jpg doorswitchtestdryerdoorswitch-undefined-undefined-1_1.jpg doorswitch lid -undefined-undefined-2_0.jpg fuse gewasherfuselocation-undefined-undefined-3_3.jpg gehydrowavefusecheck-undefined-undefined-4_1.jpg push start switch14-undefined-undefined-5_1.jpg
7/25/2023 6:44:59 PM • Beko Washing... • Answered on Jul 25, 2023
Beko washing machine causing pulled threads on my clothes model number WTL10415W
No model number given. Front Loader or Top Loader? Pulled threads are normally in front loader and is caused by a pinch point in one of the baffles. On a top loader, look for a nick in the agitator, or the type with a split agitator, a gap between the two parts.
7/15/2023 12:21:16 AM • Beko Washing... • Answered on Jul 15, 2023
Beko front loader washer dryer WDEX854044Q0G- Display keeps beeping and flashing through the wash settings.
If your Beko front loader washer dryer WDEX854044Q0G display keeps beeping and flashing through the wash settings, it could be due to a few possible causes. Here are some steps you can try to diagnose and fix the problem:
  1. Check for Error Codes: Your washer dryer may be displaying an error code that can help diagnose the problem. Check the user manual for instructions on how to access the error codes and what they mean.
  2. Check the Door: Make sure that the door is properly closed and latched, as this can cause the washer dryer to beep and flash. If the door is not closed correctly, the washer dryer may not operate.
  3. Check the Water Supply: Make sure that the water supply is turned on and that there is adequate water pressure. Low water pressure can cause the washer dryer to beep and flash.
  4. Check the Drain Hose: Make sure that the drain hose is not clogged or kinked, which can prevent the water from draining properly. Try removing any blockages or straightening any kinks in the hose.
  5. Check the Filter: The filter may be clogged with debris, which can prevent the washer dryer from operating correctly. Locate the filter on the bottom of the washer dryer and remove it to check for any blockages. Clean it out and reattach it.
  6. Check the Control Board: The control board is the brain of the washer dryer and controls all the functions. If it is faulty, it can cause the washer dryer to not operate correctly. Try resetting the control board or replacing it if it is faulty.
If none of the above steps work, it may be best to contact a professional technician for further diagnosis and repair. They can inspect the washer dryer thoroughly and ensure that it is working correctly and safely
3/9/2023 2:25:42 PM • Beko Washing... • Answered on Mar 09, 2023
Beko Wm & Wma Models Washing Machine Motor Carbon Brushes Logo
67 questions posted
Top Beko Washing Machines Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Are you a Beko Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Beko Washing Machines
Most Popular Question
water leaks out washing powder
  • Washing Machines
