I have a Water master (9 zone) model#57979,replaed fuse andbatteries,stillnot working?
Replaced fuse and batteries,past owner was jerk,didn't leave no manuals for nothing in house he had built? Where do I find manual,for this model#57979,Water Master?
there are short. go to www.repairclinic.com for to get the parts. 2) test the switch door for short and replace see the diagram 3) test the high voltage capacitor+ high voltage diode see the diagram
Each zone of the United States has a specific zone number that the compass has to be set with..
It depends where you live...Check dealer or owners manual for zone setting...You should have a reset button at dash area....If you ever change battery you will have to reset compass zone normally.....Zone numbers are all single digit I believe.....I am on east coast...S.East...Which is 8 or 9...pending state...................Hope this helps............Metalpoet..........
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
there is one fuse for all the dash gauges, so chances are you have a wiring problem to the gauge sender on the engine or the gauge is defective, which is rare.
Just had the same problem with my '05 van. I put the Master Switch in the off position. I pulled fuse #7 on the driver side sub panel, located just above the engine hood release. I then disconnected the neg. terminal on the battery. I manually opened the pass. side slider and closed it.
I reconnected the battery and replaced fuse #7. I put the master door switch in the on position. I activated the auto door switch, and it worked.
