SOURCE: Handle replacement for water dispenser
Melissa, you don't get it from the inside. Remove the drip tray by pulling it out. You should see two screws holding the dispenser cover on each side of the bottom. Remove these screws and push up on the dispenser cover, there's 3 hooks on the top. Unplug the harness from the dispenser board and get the cover out of the way. Now is the hard part. You have to get at the module itself that holds the paddle. These can be a fight. If you go to Sears.com, go to appliance then parts and post your model number you should get a breakdown of the dispenser that will guide you. Catriver..post back
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
