Turn it on to wash and has a loud clattering noise
I had a Maytag washer almost 5 years old that sounded like a Jet Engine taking off during the spin cycle. It was the Tub Bearing - there are kits to do this yourself. To hire someone it would of cost almost as much as it would be to buy a new Washing machine. Never again Maytag - it was whats inside that mattered so I bought an LG washer.
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Bad counter weights, bad damper pads, bearings?
SOURCE: loud spin noise from Maytag washer
Check the drum bearing, a load noise, and often spinning problems are symptoms of a bad drum bearing.
SOURCE: Maytag Neptune FAV6800AW Top Loading Washer Noise
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
SOURCE: make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
SOURCE: Maytag Neptune FAV6800AW Top Load Washer? makes a
kporter3
See this Clutch repair post if you want to DIY. Is your Wash tub banging around in Spin Cycle? Do you error out of Spin Cycle with dC or uC error code to the LED Console display? You can check out the TDS but I would go right to the Clutch repair post if the machine shuts down in with a error code dC or uC.
That means the TDS is producing analog voltage swings +3.5VDC to 0VDC to the input of the Control Board Conn_P3 pins 10 and 11. Those DC voltage swings are at the design limit of Wash Tub movement and the Control Board shuts the Spin Cycle down……..so TDS is working as designed.
The machine will make several attempts to redistribute the load before the error code generation failing with dC or uC error codes. Please let us know what error coded you display.
I or other knowledge owners/DIY’ers or repair folks can help you. Please other forum members chime in for support.
Don’t get hung up in Front Strut issues or other WAG’s. Fix the Clutch Malfunction and your FAV6800A will be happy.
Aka dh1200s….. **** or Rich without the ****
SOURCE: general electric top load washer model #wpre6100g1wt loud noise
Your problem could be one of 2 things either the base is pushed up in the center or the front apron is bent. The apron is the piece of metal that runs across under the top cover. To remove the front cover to see either use a putty knife to release the catch between the top and the front cover and pull front outward one side at a time.
