Question about HP Officejet Pro L7680 All-In-One Printer
Scanned images are enlarged so 1 letter size pg becomes 6 pgs to get the whole document.
scanned images are enlarged so 1 letter size pg becomes 6 pgs to get the whole document.
4 Suggested Answers
SOURCE:
  • 96 Answers
SOURCE: scan letter
Most scanners in my experience do not scan to "precisely" 8 1/2 X 11 inch letter size (assuming that was the original paper size).
A workaround is possible with some graphic programs. After importing the original incorrect scan of the document into the software a combination of resizing and/or cropping (depending on how your program works) will allow getting the exact dimensions. Then save as a new image document. Make sure to adjust for sufficient resolution (a larger document) if you plan to reprint.
Posted on Jul 27, 2009
frankgilbert
  • 613 Answers
SOURCE: trying to scan legal sized
Try to look at preview first and then see the options you have. I cannot see your screen but you have options in the scanner. Play with them. Experiment and that is how you become an "ace". Better to make mistakes and learn than have some one else tell you how with computers and printers.
Posted on Nov 03, 2010
  • 2187 Answers
SOURCE: I have a HP Photosmart
You can use the 'HP Photo and Imaging Gallery' in adjusting the image instead the built in application from Windows or OS X.
The application mentioned above is found in the HP Director under your list of programs. Select your scanner should you be asked for the device.
Once you have scanned an object it should be previewed on the 'HP Photo and Imaging Gallery'. You should be able to re-size your image using the buttons.
Posted on Jul 07, 2011
Trying to scan legal sized document onto letter sized paper. I choose redection legal to letter and it cuts off the bottom portion of the pg leaving me to believe that it is only scanning the letter size...
Nov 03, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
How do you scan?
Open the Applications folder on the hard disk on which MP Navigator is installed, then open the Canon Utilities folder and double-click the navicon.gif MP Navigator 3.0 icon. MP Navigator opens.
2. Point to Scan/Import and click 'Photos/Documents (Platen)'.
3. Place the document face-down on the platen glass, and select 'Document Type'.
How to place the document and Document Type depends on the document to be scanned.
Allow 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
Align a corner of the document with the corner at the arrow of the platen.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly if you do not leave 3/8 inches (1 cm) or more space between the edges of the platen glass and the document.
  • When you select Color Photo or Black and White Photo, the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size such as A4 or Letter according to the document to be scanned.
  • When you select Magazine(Color), the Descreen function will be enabled and scanning takes longer than usual. To reset the Descreen function, disable Descreen in the Scan Settings dialog box.
4. Click 'Specify'... and set the preferences as required.
The Scan Settings Dialog Box opens. Specify the Document Size and Scanning Resolution.
  • When Document Size is Auto Detect or Auto Detect(Multiple Documents), the position or size of the image may not be scanned correctly depending on the document. In such a case, select Document Size, such as A4 or Letter according to the document to be scanned.
5. Click 'Scan'.
Scanning will begin.
When the document has been scanned, the scanned image is displayed in the Thumbnail List area.
Oct 26, 2010 | Canon MP610 Photo All-In-One Printer
HP LJ 3030 w/ USB connection to a computer with Windows Vista Home Premium Svc Pack 2. 64-bit Operating System. Problem: When I feed legal size docs through the doc feeder, the scan is letter size. I...
Hello Steve !
The only way scanning Legal documents on this HP LJ 3030 willbe using the ADF ( Automatic Document Feeder) since the size of the flatbed its only for letter.
So, after placing the document on the automatic document feeder theres a few setting you will need to change on the printer.
Number 1 : Go to Main Menu on the printer and look for System Setup, under system set up look for Paper setup,hit ok and now look for "Def. Paper Size" and set it to "Legal"
Number 2 : you should have a button on the printer control panel (Physical printer) that says " Reduce / Enlarge" , hit it and make sure the one selected is "original=100%"
Now just hit "Start Copy" and it print LEGAL ! it worked for me
Hope this help !
You can contact me at:
eliteprintersolutions@gmail.com
Bryan
Jul 16, 2010 | HP LaserJet 3030 All-In-One Printer
Iwant to post something more than the
You can post it as image format.
Type and print your words in any word application (example office word application).Enlarge your font,use the whole page if possible. Print the document. Scan the document and save as image file.
Now the problem is if you save the image, the file size should not exceed the required maximum size to upload by simple uploader. You can use image resizer. It can be download from the add-ons of any web browser for free. (will be found on the Tools menu of the page when click add-ons). When installed completely, right click on the image file and click resize. Use thenew image file with less file size and upload it to Facebook.
All your friends will see and read the words completely.
Let me know if you lost in the procedure so I can help you on your way to solve your problem.
Please rate. Thank you for using Fixya.
Jun 07, 2010 | Facebook Social Network
Scan letter
Jul 25, 2009 | HP Officejet 5610 All-In-One InkJet...
The text of a document will not print. The
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Jul 22, 2009 | Epson Stylus CX4400 All-In-One InkJet...
Scans are enlarged after switching to vista 64bit
hmmm... just the set pixels properties to medium..maybe the pixels properties is to high..it can cause long time scanning and large images results ..thank you
May 15, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
I'm trying to enlarge a scanned photo, then print it on my Epson
Hi, scan at around 350dpi, save the image file as a jped and then import it into word or other program that will accept jpegs and you can make the image as big as you want up to A4 or letter size (depending on the paper size you use
Jan 27, 2009 | Epson Stylus Multifunction Inkjet Printer/...
We have a canon MP610 printer scanner combo, I work in a dentist office and am trying to scan a x-ray. When I do it is'nt picking up the detail very well at all. I think I need to adjust the settings but I...
the only way to get a little more detail out of this printer with x-rays is to INCREASE the DPI resolution. there are no other adjustments that are abailable.
The Scan Settings dialog box opens when you click Specify... on the Scan/Import Documents or images screen.
The Scan Settings dialog box allows you to specify advanced settings for scanning.
Document Type
Select the type of document to be scanned. To scan photographs, select either Color Photo or Black and White Photo. To scan text documents, select either Color Document, Black and White Document, or Text(OCR). To scan magazines, select Magazine(Color).
Document Size
Select the size of document to be scanned.
Auto Detect: Detects document size automatically.
Auto Detect(Multiple Documents): Select this when scanning multiple documents at one time.
Select Stitch-assist to scan the left and right halves of a document separately and combine them back into one image.
Reference See the section below for details.
Scanning images Larger than the Platen (Stitch Assist)
When you select Custom, a dialog box in which you can specify the document size opens. Select a Unit, then enter the Width and Height and click OK.
Important When you select Auto Detect the position or size of the image may not be scanned correctly depending on the document. In such a case, specify the document size, such as A4 or Letter according to the document to be scanned, and align a corner of the document with the corner at the arrow of the platen.
When you select Auto Detect(Multiple Documents) allow 3/8 inches (1 cm) or more space between the edges of the platen and the document.
If not, some images may not be scanned at the correct positions and sizes.
You cannot select Auto Detect(Multiple Documents) or Auto Detect when Document Type is Text(OCR).
Scanning Resolution<<<<-------------------------------------------------------------<<<<<<<<<<
Select the resolution at which to scan documents. The following scanning resolution can be specified:
Text(OCR): 300dpi, 400dpi
Others: 75dpi, 100dpi, 150dpi, 200dpi, 300dpi, 400dpi, 600dpi
The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail. At high resolution, scanning takes longer and file size becomes larger than usual. See the section below for details on resolution.
this should answer your question , feel free to post here agian if you need more help.
Regards, and thank you for using fixya.
Oct 23, 2008 | Computers & Internet
HP Officejet Pro L7680 All-In-One Printer Logo
Clive
Clive
Thomas F. Schneider
