SOURCE: 17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
SOURCE: monitor goes black
resolder the board see if there is a crack solder on the pcv board resolder it
SOURCE: LCD monitor comes on for about 10 seconds then goes off
It sounds like the power supply board on the monitor may be faulty (that or the backlight).
You could test it on another computer to see if does the same thing (or another monitor on your computer).
If the same problem occurs on this LCD you'll either need to get it repaired under warranty, or pay for it to be repaired. Or just throw it out.
SOURCE: Display goes out
I had a problem with my 1916w monitor where it came on and the monitor began to squeal, the screen went black and the noise stopped. The monitor power indicator whent from green to orange. It turned out to be two bad (domed) CapXon 1000 microfard 25v dc capacitors on the power board. This brand of capacitor has been a known cause of problems in various makers monitors. Replace these two capacitors and any others that have domed tops with a good brand of capacitor of the same rating. Replacing these two capacitors fixed my problem. I have disassembly instuctions for this monitor in answer to another persons problem in FixYa where he inquired how to get the covers off the monitor. Good luck and have a merry Christmas.
SOURCE: Screen works for awhile but then goes blank.
if u have a problem wih your Westinghouse Monitor LCM-17V8 email me for solution or if you want to dispose of it; email me at
[email protected].
Thanks
Ekow
