20 Most Recent AOC LM729 17" LCD Monitor Questions & Answers
Black Screen but has power.
1280 x 1024 @75Hz made 2003 a real relic, gee it ran for 14 long hard years. amazing. the CCFL tubes are dead , or dim, all CCFL this old are dead. or weak or intermittent and all are bad. the background lamps died in a dim room point flashlight to lcd see, data, bingo for dead CCFL. the MON will fail on all PC connected to. for sure. best reso and max is 1280 X 1024 @ 60Hz it does not do all resolutions below that, see the manual for the few it does, AOC LM729 https://www.manualslib.com/manual/689817/Aoc-Lm-729.html?page=7&term=ccfl&selected=3#manual CCFL bad 99% or 1% bad inverter 600v
5/13/2022 9:37:25 PM • AOC LM729 17"... • Answered on May 13, 2022
Connect rf modulator to aoc monitor
Connect rf modulator to aoc monitor? This trouble maybe power supply or inverter boards is defective. first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts if you have any question,please let us know email:[email protected],we sincerely hope we can help you! you can also check this boards whether suit you: 715L1103 AOC IDPC7425A3 Power Supply for TFT1780PSA LM729
12/23/2014 8:55:58 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
Nothing display on my AOC monitor even my computer
check RAM or replace it
12/23/2014 8:55:13 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
Monitor menu problems
Hai Ejor,
You need to replace the front panel menu buttons,
Regards
Aby
12/23/2014 8:54:40 AM • AOC LM729 17"... • Answered on Dec 23, 2014
3answers
AOC LM729 LCD - Go to; bright white lines, blank, computer view and lines, blank. Yeah, please help!
This is an old post but maybe this will help someone else......
I have sold a lot of these LM729's a few years back and now, out of warranty, they are starting to show these same symptoms. I was stumped at first but finally did some real testing on them and found that in every case it it the 1000uF capacitors that are faulty. Look at the board and you will see 2 capicitors, the barrel shaped components, that have 1000uF printed down the sides of them. Both of these should be replaced even if only one is bad because chances are the other will go soon as well. You can usually pick these up for under 2 bucks each at your local Radio Shack. Get ones rated for 35 volts (35V), the ones on the board are 16vols but I usually try to go a bit more robust when I replace capacitors. The rating is just how high the voltage can go so it's okay. They are usually more durable since they are to handle higher voltages. Just take the LM729 apart, remove the power board, desolder the capacitors, clean up the holes, (Be gentle in desoldering them, you don''t want to pull the things, you will pull off and possibly tear the copper foil pad that you need to solder the new cap to) Install the new capicitors minding the polarity, as in there is a MINUS sign on the capicitor and this must go in the hold with the matching MINUS sign. Solder the leads, clip the excess off. Reassemble and you'll probably find that LM729 working just fine! These are very good monitors and very rugged. AOC isn;t at fault for this failure. The Chinese have been making scads of bad capicitors for a few years now. Anymore, if there is an electronic failure it can be traced back to bad capicitors.
12/23/2014 8:52:20 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
Ayaw po magopen ng aoc computer monitor.. may
ang problema jan ay power supply mo bka mababa masyado ang kuryente marunong ka na bang mag set up ng PC
sana natulungan kita
12/23/2014 8:50:52 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
Aoc LCD monitor problem
If some of the pins inside the monitor cable are bent or broken you can losr primary colors and cause this. Check them. If they seem OK try reseating both ends of the cable. If no go, then try the monitor of a differnt computer to see wether its the videocard or the monitor thats defective.
12/23/2014 8:48:24 AM • AOC LM729 17"... • Answered on Dec 23, 2014
3answers
the inverter needs to be replaced
not real hard, but must have some knowledge of the process
12/23/2014 8:47:44 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
My aoc have power light
repalce data cable
12/23/2014 8:47:14 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
Aoc lcd contains a small red dott
You just lost a pixel..
12/23/2014 8:46:47 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
My aoc model 729 lcd monitor displays windows
Your resolution is too high or too low try changing it.
12/23/2014 8:46:04 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
Problem inAOC LM725 monitor
Maybe one of the volume buttons on the front panel control is randomly shorting. Check it out...
12/23/2014 8:45:30 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
AOC MODEL 7VLR NO POWER
Hi...there,
It's seems your backlight inverter are busted...Need to replaced a new one or repaired it.
12/23/2014 8:45:01 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
Backlight inverter aoc lm729 Schematic diagram
Here is the service manual: http://elektrotanya.com/?q=showresult&megnev=AOC%20&megnev2=LM729%20&kategoria=&kat2=all
You will need test lamp to verify if it is the inverter or the lamp assemblies.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
12/23/2014 8:44:09 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
My AOC 19
my 3 aoc tft1560ps 15inch back light is off plsss help me capacitor replace already
12/23/2014 8:43:29 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
AOC 2036 LCD
You can get the drivers from www.driversguide.com
12/23/2014 8:42:58 AM • AOC LM729 17"... • Answered on Dec 23, 2014
4answers
Problem with the risolution
To my understanding, an AOC LM729 is capable of 1280 x 1024 and therefore should be able to display your preferred 1024x768 .
Perhaps you need to set the PC's Display Screen Refresh Rate to 75 Hz or lower (DisplayProperties/Settings/Advanced/Monitor).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
12/23/2014 8:42:14 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
Aoc lm725 display off after few seconds
I've had a very similar issue on many Dell Monitors. Mine have been under warranty and they usually send me a new monitor, but I believe the issue lies with the power supply within the monitor.
12/23/2014 8:41:41 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
Inverter board
just change the 4 bloated caps on the board (2)100mfd 16v and (2) 470mfd 16v
12/23/2014 8:41:06 AM • AOC LM729 17"... • Answered on Dec 23, 2014
2answers
Blackout monitor
ur video cable should be replace
if helpful then rate me
12/23/2014 8:40:22 AM • AOC LM729 17"... • Answered on Dec 23, 2014
AOC LM729 17" LCD Monitor Logo
154 questions posted
Top AOC Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • AOC Computers & Internet
Most Popular Question
ayaw po magopen ng aoc computer
  • Computers & Internet
