20 Most Recent Hyundai ImageQuest 19 L19T LCD TFT 19" LCD Monitor Questions & Answers
Getting stations
Do a factory reset and see if that works.By the way Irish is english
2/8/2018 2:28:22 AM • Hyundai... • Answered on Feb 08, 2018
I need to know how to reset my monitor to factory defaults
Factory Setting & EEPROM Initialization Method
Factory Setting Method
- Connect the signal cable and power cable to the LCD monitor.
- Press Power switch with pressed MENU key.(Menu key + Power key).
- Then, a User can change the factory setting value in OSD menu.
- Save changed value and Turn off the power s/w.
- Turn on the power, adjust the screen.
2/10/2017 6:18:35 PM • Hyundai... • Answered on Feb 10, 2017
Hyundai L19T : power bottom
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom (look for discoloration of the circuit board around the base of the capacitor) need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the unit will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and/or inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are SURE it's only doing supply output ripple filtering,
and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
Backlight related video here:
http://www.youtube.com/watch?v=6XoF6QZ1dmw&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, computer power supplies and motherboards, and other electronic equipment.
The parts are cheap, and skill required is minimal.
A great parts source is Digi-Key, and you can order the parts online at www.digikey.com
They typically cost under a dollar a piece plus a flat shipping rate.
The parts usually arrive one business day later.
If you watch the third video, you will see that even someone with no soldering experience can perform these repairs as demonstrated by the woman in the video.
7/21/2011 10:24:48 AM • Hyundai... • Answered on Jul 21, 2011
Hyundai L19T lcd monitor. Monitor powers up but
Sounds like you have some bad electrolytic capacitors.
If you are tech savvy, open up the unit and look for capacitors that have bulging tops or leaking electrolyte / bulging at the bottom and replace any/all that look like this.
In most cases, this will fix you right up quick.
It's the right age for this to be the most likely issue.
The capacitors will be near the power input and the inverter stages of the circuitry.
2/22/2011 6:50:08 AM • Hyundai... • Answered on Feb 22, 2011
Power supply has shut down
what system is it connected to laptop or desktop? if a laptop try using the Fn+ Monitor buttton ...it may be in a different mode .. if desktop try another monitor if it works then the issue is something else or if it still does not work then it could be a loose video card try reseating the Video card
10/6/2009 5:26:32 AM • Hyundai... • Answered on Oct 06, 2009
0answers
Driver ICC PROFIL
Be the first to answer 4/23/2014 3:07:22 AM • Hyundai... • Posted on Apr 23, 2014Be the first to answer
0answers
I HAVE A HYUNDAI HY960 HOME THEATER SYSTEM. THE REMOTE HAS GONE BAD AND I NEED A NEW ONE. Is ANYONE SELLING one?
Question edited for clarity and spelling. Please do not type in all CAPS, it is considered SHOUTING and is more difficult to read! You are the only person in the world to have this make and model combination! https://www.google.com/search?q=HYUNDAI+HY960 Genuine OEM Remotes or Facsimile Remotes are readily available. https://www.google.com/search?q=home+theatre+replacement+remotes ..
12/14/2023 6:56:22 PM • Hyundai... • Answered on Dec 14, 2023
2answers
What are the spec on a Hyundai Koral Pro 10M4 power supply?
Hyundai power supply Model: SAW30A-120-2000U Input: 100-240V 50/60Hz 0.8A Output: 12V 2000mA www.szyingyuan.com image-undefined-undefined-0_2.jpg
4/30/2021 3:11:26 PM • Hyundai... • Answered on Apr 30, 2021
On a 2009 Hyundai 1.6 on the chains how many links separated the 2 cams
are you sure that it is a 1.6 motor as 1.6 motors use a belt not a chain your statement that it has 12 on each cam indicates that it is a v engine or a double over head engine in any case you do not count links but put the colored links directly over the sprocket dots you have to use a cam locking tool to get it right
8/3/2018 12:28:43 AM • Hyundai... • Answered on Aug 03, 2018
Hyundai ImageQuest 19 L19T LCD TFT 19" LCD Monitor Logo
15 questions posted
Top Hyundai Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Simon Atkinson
Simon Atkinson
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ImageQuest Hyundai
  • ImageQuest Hyundai
Most Popular Question
need know reset monitor factory defaults
  • Computers & Internet
