20 Most Recent
Hyundai ImageQuest Q17 17" LCD Monitor Questions & Answers
I have tried playing my PS3 through my Imagequest
I have always had good luck with DVI to HDMI converters. My advice would be to find another monitor and see if it works on that. If it does, then you know the signal is getting through. It might be a setting on the PS3 as well. I'm only familiar with PC to monitor conversion.
1/19/2018 10:03:07 AM •
Hyundai...
Answered
on Jan 19, 2018
Adjust screen brightness
Yopu can adjust the brightness of the monitor from the avaialbe panel buttons Alternatively you can do so from the Operating Sytem brightness control which depends on the platform you are using. If its windows you can navigate to control panel and the power settings and adjust the brightness by sliding the slide bar as desired.
9/23/2013 3:03:25 PM •
Hyundai...
Answered
on Sep 23, 2013
Speaker in screen dosen't work
a normal minijack (3,5 mm) cable, with the same plug in both ends.
if you have a cable already, try to adjust the volume using the buttons on the screen
3/10/2009 4:17:06 PM •
Hyundai...
Answered
on Mar 10, 2009
Monitors goes black - Hyundai Q17
I had the same problem some time ago.
After dismateling the power-supply unit it apeared that there was en crack in a solderjoint at one of the power transistors. This transistor has 3 legs (TO220 I believe), from which the middle leg had a solder crack, probebly due to thermal stress. Just resolder and it worked again....
Its worth a try I think.
Succes, Wim Steenhuis.
1/14/2009 10:18:47 PM •
Hyundai...
Answered
on Jan 14, 2009
Screen does not start (switch on)
Sounds like a mode issue. Make sure you have the pc set to a compatible mode for the monitor. You may also want to double check the vga cable is firmly set in the monitor and pc.
12/4/2008 10:06:04 PM •
Hyundai...
Answered
on Dec 04, 2008
