Konica Minolta Bizhub c203 Copier Logo
A
Anonymous Posted on Aug 11, 2014
Copies are Very Dark - Konica Minolta Bizhub c203 Copier
Konica Minolta Error Codes and Solutions
Level 2:
  • Expert 210 Answers
  • Posted on Aug 21, 2014
Expert
Level 2:
Answers
210
Questions
0
Helped
153694
Points
393
Are the prints ok? Did you tried to print a test page as follow: Utility -> User Settings -> Print Settings -> Print Reports -> PS Demo Page -> Start. Check this page and if it is looking OK, you isolated the malfunction to scanner area. Try a scan and check the quality, afterwards try to copy from DF and try a glass copy, check the quality.
If you need anything else, just drop us an email at [email protected]
Also, please visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
1helpful
Konica 1212 copies to dark
1st the basic cause of dark/grey copies DUST. Clean w/ alcohol cloth then dry cloth totally all mirrors and the platen glass both side. If still dark check the "Optic slit " right in the upper of your halogen lamp remove it, still dark Check your halogen lamp maybe it already oxidized. The last solution adjust the CVR .
Very dark copy
dark copies or background on the copies
if back ground on the copies need to replace the PCU unit
I have a FP7113 it only makes dark copies
dark copies you mean there is a dark background but image is still there?
it is usually happens when all mirrors and **** glass becomes dirty. you should clean it
well if you mean an image with pure black copy output, probably your exposure lamp is busted or the thermostat is open. :)
2answers
Copier prints too dark
Clean the mirrors ,lens ,optical unit.
2answers
DARK SPOTS
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
2answers
Dark copies with overprinting
Cleaned the coronas as per instruction book. Done this before but this time it made a difference.
Copies are dark
No. It would most likely be the opposite.
The stripes could be caused by contamination of the dev roller, fixing rollers or marks on the drum.
You could also clean the laser ****-glass.
Dark lines on edges of copies
make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
New scx-4521-FG/ too much fad
The darkest copy setting is obtained when the contrast is set to dark and the toner save is turned off. If the originals being copied are too light, this unit has trouble seeing the image and the copies are extremely light as well. If the originals are good and dark, try using original toner cartridges.
Be blessed.
Copies Coming out Dark
Please give modell number and name. Cant give you a advice out into the blue :-)
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
