20 Most Recent Sharp AL-1641CS Laser Digital Copier Questions & Answers
5516 solution of error h5 01
I would go into service mode if i were you. To get into the service mode is # * Clr * then enter 14
6/29/2018 2:12:53 PM • Sharp AL-1641CS... • Answered on Jun 29, 2018
2answers
DARK SPOTS
Are the dark spots random and moves location with every copy or are they at exacly the same place on every copy? Random you will need to remove the drum/toner and use a blower to clean the inside of the machine,failing that replace the drum unit.If the spots don't move clean the top glass.Let me know
5/2/2017 12:55:53 PM • Sharp AL-1641CS... • Answered on May 02, 2017
I am getting an "H 4" message and the machine won't print.
replace the fuser unit try this site for parts as a start Precision Roller Printer Toner Cartridges Parts and Supplies Office... Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/13/2016 1:01:26 AM • Sharp AL-1641CS... • Answered on Mar 13, 2016
Sharp printer MX-2600N, error H501, clearing code, the error code window stays on menu screen
has the fuser been replaced?? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
1/27/2016 4:22:37 AM • Sharp AL-1641CS... • Answered on Jan 27, 2016
Why am I getting an "H 4" message and the machine won't print?
fuser temerature issue , or due to power fluctuations , check thermistor and thermostat, and hologen bulb, but run a crop 14 error clear first
11/4/2014 8:51:30 AM • Sharp AL-1641CS... • Answered on Nov 04, 2014
Sharp ar153e code error f4
this is H4 not f4 c-photo-c-phot press 14 from up and down key press print key
6/16/2014 11:22:38 AM • Sharp AL-1641CS... • Answered on Jun 16, 2014
Sharp ar5516 making cracking sound while copying
Try unplugging it and wait for 20 seconds plug it back in. It sounds like the bed of the scanner might be off and resetting it will align the bed again
5/13/2014 6:19:28 PM • Sharp AL-1641CS... • Answered on May 13, 2014
Sharp copier 1641cs
I am having a problem in copier sharp 1641CS, this E7 appears on the display, and with that the copier is dead ... What to do?
1/20/2014 4:08:14 PM • Sharp AL-1641CS... • Answered on Jan 20, 2014
Code error h4
check USB cable
9/26/2013 1:41:27 PM • Sharp AL-1641CS... • Answered on Sep 26, 2013
Opertor reset key
Can you explain please?
1/30/2013 2:26:16 AM • Sharp AL-1641CS... • Answered on Jan 30, 2013
How do i clear error mx-26000x h5-01
Find out why it is jamming in the Fusing unit.# * c * 14 should do the trick.Before entering service mode to clear the error make sure the machine is in "Copy" mode
1/30/2013 2:07:56 AM • Sharp AL-1641CS... • Answered on Jan 30, 2013
Need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
11/1/2012 9:52:35 PM • Sharp AL-1641CS... • Answered on Nov 01, 2012
Sharp AL-1641CS Laser Digital Copier Logo
Popular Tags
144 questions posted
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Sharp Office Equipment & Supplies
Most Popular Question
5516 solution error h5 01
  • Office Equipment & Supplies
