20 Most Recent
Lanier 1205 Copier Questions & Answers
Lanier 5618 Network
Hi, Lanier 5618 is not a Network Copier. However, it may be installed on one PC and shared from there.
Drivers are available from LANIER Official SupportHope it helps! Good Luck! Thanks for using Fixya!CreativeTECH
Cannot connect to lanier printer/copier
Ours Lanier 5618 has a network adapter , finally succeeded to setup via it by : "add printer wizard" , after choosing 'Standard TCP/IP Port' ; we choose " Ricoh Generic Network Printer " instead of "Generic Network Card" at 'Dvice Type' .......
Cs546
The problem in the fuser unit.Check and clean the rollers ,thermistors,thermofuses.
Lanier 6735 Copier
Sounds like you need a new cleaning blade. It is located inside the process assy behind the drum.
Hi have a lanier copier
Hello!
If you say that you see old ghodt copies the problem is with the Fuser Roller in the Fusing Unit.
If this is right i advise you to call a Tech (if you do not have the skills to change it)
See you!
Lanier 5622 says following output tray is full
Hello!
Why did you change the fotoconductor Unit???? This part of the machine is to create the image.
Your problem is in the tray. Meaby a broken switch. Take out the all tray and look inside to see if there is same obstruction.
If you do not see anything i advise you to call a Tech.
Dont waste more money if you dont know what your doing. This is the best advise i can give you.
See you!
Can you please tell us
Hello!
I suppose that it is a printer.
In this printer the toner waste goes to the Transfer Unit.
Open the right door and you will see the trasfer unit. You have to take it out and open it. Then just empty it to a bag.
Take a look at this picture
Where is the waste toner
For your in formation, the waste toner bottle locates at the
back side of the printer. Just go to the back side of the then open the back
panel of the printer and you will find the waste toner bottle there.
I have a lanier ld425c
Hello!
I am not 100% sure but i think you can calibrate your touch panel.
Follow this steps:
- Press yellow key.
- On the key pad press 1999.
- Press Red Key five times.
After that you will see the option to calibrate your panel. You just need to follow the wizard.
If you have any dought reply to me.
See you!
Cannot insert Tray 1 into
It is not seeing tray in the machine. Might be a piece of paper stuck behind the tray stopping it from going in and stopping it from detecting the tray?
I have a black line
It could likely be the drum. Is the line on copies and prints, or just copies? If it's just on copies, it's not the drum.
Lanier model 5627,fault code SC542 upon power up
try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON
And thats it
