20 Most Recent Lanier Ld445c Ld435c Ld430c Ld425c Ld420c Newdrum Kit Questions & Answers
in bypass put envelopes in short edge first, push the # button, select size of envelopes and OK it, (needs to be told of size)-Carl
Lanier Ld445c... | Answered on Nov 19, 2015
You have to set up the settings in user tools on the operation panel.
Lanier Ld445c... | Answered on Dec 14, 2014
after refill the toner may be bias charging roler is not proper fiting
or toner cartridge is not proper insert
Lanier Ld445c... | Answered on Aug 19, 2014
Fuser pressure error, service call
Lanier Ld445c... | Answered on Nov 27, 2013
This problem is referred to as color to color alignment. Most color laser systems have a rough adjustment by means of a screw somewhere and a fine adjustment that is done in diagnostic mode as part of a setup routine. Try the latter first by locating your manual and looking through the troubleshooting guide which should explain how to force the machine to do an automatic color alignment. Your manual should be available online from your manufacturer's web site if you can't locate it. If this doesn't work you will need to take it in for servicing unless you are handy with tools and can find a service guide for your model.
Lanier Ld445c... | Answered on Nov 10, 2013
Lanier Ld445c Ld435c Ld430c Ld425c Ld420c Newdrum Kit Logo
Popular Tags
24 questions posted
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Office Equipment & Supplies
Most Popular Question
print enevelopes without jamming in
  • Office Equipment & Supplies
