Http://www.fixya.com/support/t383287-canon_mp530_u052_error
my answer is #3
be sure to purchase the correct replacement part. Canons website will give you the serial number. I purchased the part on amazon.
CHECK CARTRIDGE
U052
Re-set the print head. If the error is not cleared, the print head
may be defective. Replace the print head.
SOURCE: Error code U052
This is Vikram Kumar Thumu from India-Hyderabad. I have seen your message on the issue. I would like to provide my solution on the issue.
Well, I don't think this is an issue with Hardware malfunction of the Printer... However, I suggest you to try few troubleshooting steps before you replace the ink cartidges for Printer.
Please try steps of below link:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13800
This is recommend link of Canon .. The steps that are mentioned in the article could something work...
However, once if you are done with steps, I suggest you to contact Canon and email the issue and they can provide information on the issue.
You can mail Canon at below link :
Once if you the link, you need to click on the link Email in the webpage.... and email the issue. I hope that this will resolve the issue....
if you have any queries on the issue, you can email me at [email protected]. I'll be glad to help you out!!!
Bye...
SOURCE: Code U052
Dear dgthorpe,
This indicates that printhead of your printer faulty. Commonly this problem come with short circuitry problem in printhead so it may harm logic board and carriage unit too. I suggest you to try checking with another printhead first.
Regards,
SOURCE: Canon printer not printing and gives error code U052
you have a purge unit problem, cost more than the printer is worth unless it is under warranty,
Canon small printer technician
SOURCE: Pixma MX860 - Error Code U052
Kindly follow this link: http://support-hk.canon-asia.com/contents/HK/EN/8000138702.html
Thanks
Sachidanand
Testimonial: "Thank you. I thought I had already reseated the component, but the graphics of this response were very helpful to insure I did not miss a step - K"
