Canon PowerShot SX100 IS Digital Camera Logo
A
Anonymous Posted on Jul 11, 2014
Where is the battery compartment for time/date for my Olympus Stylus850 SW ?
Vick
Level 2:
Scholar:
New Friend:
  • Expert 92 Answers
  • Posted on Feb 12, 2015
Vick
Expert
Level 2:
Scholar:
New Friend:
Answers
92
Questions
0
Helped
16417
Points
259
If you mean the battery for the time/date in you camera, it does not have a compartment for it, the battery that keeps the time/date is internal. It is usually a button cell like what a watch uses. To replace the memory battery requires to take the front and back panel off your camera, not an easy task. Most of the time it is easy and requires you to remove all the tiny screws around the camera, once you remove all the screws you can pry open both front and rear panels, you do have to hunt for that little button cell battery as every camera has it in a different location?
Date on my photos
The date and time (and a lot more) are stored with every photo in its EXIF metadata. If you want this printed with the photo, please consult the documentation for whatever program you're using to print your photos. Depending on the program and printer, you may print the date/time on the image, in the margins, or on the back.
Need to have date printed out on my photos with my olympus stylus 1030 sw camera
Need date and time on photo
Olympus u770 sw 7.1 No power, battery fully charged, lens cover is open. No lights no screen nothing. Camera has been perfect for almost 4 years just shut down whilst being used hence lens cover open. Any...
Hi
Sorry to hear about your issue with the Olympus mju 770 SW. There's a couple of things you can check and try, before thinking about a repair or binning the camera and getting a new model.
1. Check the contacts on the battery are clean?
2. Clean the contacts inside the cameras battery compartment are clean?
3. Is the charger actually charging the battery? Try another battery or see if you can test the existing battery with a multi-meter to check there is some power in it.
It is fairly common for chargers to fail, so it's worth checking out but don't go spending money on a new charger unless you know it will fix your problem.
Hope this helps
David
5helpful
Olympus 770 sw lens cover not closing
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they're just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
1helpful
Date & Time Stamp on PC
By default Olympus cameras do not print the date on the images when they are downloaded to a PC. Olympus does not include this functionality because they feel that it detracts from image quality. There is a function of the camera called print order that you can set that it will print the date on the images but this is only if you take the card to a photo processing store. However if you use the Olympus Master software and print the images that you have previously transferred there is a check box in the print setting window that you can add the date and or time to the printed image.
2helpful
Cannot print pictures with dates in my olympus stylus 770 sw
2helpful
Date Imprint
Throw the cam and buy a good one, this camera was bought by me to record the site photographs but with out a date imprint on them they are not even worth a tissue paper.
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
