Home Logo
A
Anonymous Posted on Jul 06, 2014
How do I adjust the fill level "screw"; water is overflowing into the overflow tube and the fill stop won't shut off?
I have tried adjusting the plastic screw which controls the fill level but no matter how I turn it, the water overflows. My water bill will be huge and all I can do is monitor every flush and turn off the water at the shutoff valve. What a pain! This toilet has been nothing but problems since purchased!!!
4 Related Answers
Anonymous
  • 239 Answers
  • Posted on Jan 04, 2009
SOURCE: the fill valve in my toilet tank leaks.and water level can not be
there are different fill valves if you have the one w/ two screws on top you have to tie down the one on your left hand side if you have the one w/ a side plastic long screw adjust that one
Anonymous
  • 16 Answers
  • Posted on Jul 10, 2009
SOURCE: Toilet continues to run. THe plastic float cup
The adjustment is inside. It just needs to be adjusted.
Dan Damron
  • 39 Answers
  • Posted on Aug 05, 2009
SOURCE: Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
radar001
Bob Korsu
  • 1051 Answers
  • Posted on Feb 23, 2010
SOURCE: WATER KEEPS RUNNING ON TOILET
The screw can be used but only for minor adjustments. The missing tube should be replaced. If this doesn't solve the problem purchase a repair kit. The repair kit comes with everything you need for about $20 and can be installed yourself (saving $$$ if you called a plumber)
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 • Home
1helpful
After my toilet fill valve shuts off, water continues sipping into tank slowly. This causes water continuously overflow through overflow tube.
check that the fill valve was installed correctly
adjust the float level so that when full the cistern water level is around 1/2" below the over flow pipe end
what you have now is that the inlet water is not being shut off correctly and the water is still coming in and flowing out of the overflow
The fill valve will not shut off in the toilet tank. Water continues to run out of the overflow tube of the valve into the overflow tube of the toilet., even after the valve has been adjusted.
After flushing the toilet, water still fills the tank till then the shuts off valve reaches a certain level. When the shuts off valve reach the level it disconnect the water connection to the tank and the filling process of the tank shuts off.
So, if your fill valve didn't shut off then maybe there's a problem with the shuts off valve, open the fill valve and fix it. If you can't fix it call a plumber for it.
Water is not coming out on the top of the fill tube that connects to the overflow tube
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
The toto toilet keeps running over the overflow tube in the tank. I cleaned the valve which worked for a while but now is back to running. Should I replace the gravity valve?
If you can lift the float arm and it stops the water flow into the tank then the float arm needs to be adjusted. The proper adjustment will stop the water flow when the level is between 3/4" and 1" from the top of the overflow tube. The newer style valves have an adjustment screw that is easily located and can be adjusted without any dis-assembly.
Feb 19, 2011 • Toto Home
2answers
Toilet system will not completely stop dripping, resulting in constant drip from overflow. How do I stop it?
Is the drip comming from the small fill tube going into the overflow? If so you may need to raise it a little. The nost common leak is from the flapper or seal. On rare occasioms the flush valve itself has a defect that will cause it to leak. Take a close look at the problem and Im sure you will find it. I hope this helps.
May 14, 2010 • Home
1helpful
How do I adjust tank fill valve to increase water level in toilet?
There are many different fill valves out there so it would be a little hard to tell you how to adjust your particular one without knowing the brand and type of the fill valve.
So I will give you a generic adjustment.
Look for someway/something to adjust your float in the toilet tank.
There should be a screw, moveable metal, something that will adjust your float.
Once you locate the adjustment, you can then adjust your water level in the toilet tank.
Adjust the water level in the toilet tank to be about a 1/4-1/2 inch before it flows out of the overflow tube when the water shuts off.
Good Luck, I hope this helped.
Please rate me, Thanks
Mar 11, 2010 • Home
2helpful
Is there a manual. The water keeps running.
the fill valve shut off level setting is too high. water in the tank is overflowing in the overflow tube. adjust fill valve to shut off at lower tank level
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
