20 Most Recent Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Questions & Answers
Fill water squirts out "vents" at top and even
replace the valve rubber at the top of the inlet control
9/6/2017 5:38:23 AM • Kohler Toilet -... • Answered on Sep 06, 2017
Flushing problems
Tank needs more water and the flapper has to stay open longer by adjusting chain so the flapper goes up higher when you flush the unit. Practice and you will get it right.
4/9/2017 1:29:34 AM • Kohler Toilet -... • Answered on Apr 09, 2017
How do i adjust the
should be a little screw on top of flush valve...or just bend ball arm alittle till the water level is met
4/16/2014 2:18:18 PM • Kohler Toilet -... • Answered on Apr 16, 2014
Kohler toilet troubles
The holes around the inside of the bowl may be clogged, try using some CRL and scrubbing the holes with a good stiff brush.
4/9/2014 6:31:51 PM • Kohler Toilet -... • Answered on Apr 09, 2014
Screw loose in securing toilet to flange
Hopefully you can tighten it Sometimes the flange bends up or can break. Many a flange is not held down properly with good enough screws or the plywood has been rotting etc. If you can tighten it or loosen it then it has to be cut off with a recipricating saw or hacksaw and replaced.
11/30/2013 3:15:13 AM • Kohler Toilet -... • Answered on Nov 30, 2013
Water level too high in Gruppo Italia in-wall cistern
check if mechanism that releases water when you flush is tight so no water escapes. As for water level, you can adjust to less in the tank.
7/30/2013 2:00:41 AM • Kohler Toilet -... • Answered on Jul 30, 2013
Water is not coming out on the top of the fill tube that connects to the overflow tube
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
2/16/2013 9:02:53 PM • Kohler Toilet -... • Answered on Feb 16, 2013
3answers
How do you get the top plastic cap off the Kohler Ingenium flush
My Kohler Ingenium has no pins. The white cap is attached to the grey lever which must be lifted up before twisting both one-eighth turn counter-clockwise, and lifting off of fill tube. Turn the water supply back on and flush the tube out (cover with cup first!). Use a thin wire rod about 12" long to gently poke down into fill tube to clear any clogs. Also check where the small flexible fill tube exits from the main fill tube. Reassemble and cross your fingers.
1/5/2013 2:11:25 AM • Kohler Toilet -... • Answered on Jan 05, 2013
Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
Popular Tags
86 questions posted
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
water level high in gruppo italia in
  • Home
