Good Afternoon Friend,
I understand that your Frigidaire range overheated, so you unplugged it and plugged it in the next morning. I also see that when you plugged it back in there was a "PF" code displayed as well as some melted plastic. The "PF" code means that there was a power failure. You can clear that by pressing any button. As far as your appliance overheating and melting plastic, I suggest contacting the manufacturer directly for further assistance. They might be able to point you in the right direction to have it repaired. Hope this is helpful.
-Best Regards-
WP
SOURCE: Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
SOURCE: frigidaire plef398ccc displayed 'er' now won't heat cooktop/oven
You could have a problem with the user interface board, which is #97A in the attaced breakdown, part #316239500. Hope this helps.
SOURCE: We have a frigidaire oven with flashing time and PF on display
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
SOURCE: frigidaire electrolux model plef398ccd
You will need to replace the control board. Here is he part to order.
All
parts come with a 365 day, any part, any reason return policy.
Good Morning Paul, thank you for your post!
Based off what you have described your Frigidaire range, PLES389DCC, is providing you with an error code of "PF" and "F1" as soon as you turn it on. An error code of "PF" stands for power failure this could be a possible problem with your control panel or power cord.
The error code "F1" stands for a runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. If you continue to have issues with the "F1" error code I would recommend having a professional technician out to your home for proper diagnosis and replacement of any electrical components. Hopefully this information has been helpful. -Matt
