20 Most Recent Frigidaire FEF336BC Electric Kitchen Range Questions & Answers
There are mounting plates that recess the plug in the wall. Hardware stores have them in the electrical parts department.
Frigidaire... | Answered on Apr 15, 2017
although you dont have hte model number , that is indeed a correct and valid part number for the control lists for a about $120. since your back there give a quick look at the wiring into the unit, is that ok ??? adn where the burnout is on the control does it appear to have shorted out against the back wall??? perhaps a relay on the board just blew??? i really wouldn't thinkn tha another component was goning to make that go bad, also ck the bake and broil elements for continuity, perhapa wire fell off the element blowing out the control
Frigidaire... | Answered on Jan 04, 2017
I'm not sure how I was registered as having a problem with an electric range; my problem was with my Sunbeam electric mattress pad.
I used one of the suggestions I read here. I unplugged the connection to the mattress pad and blew into the receptacle to clear any dust or lint from it. I reconnected everything, plugged it in, and the problem has been eliminated.
Thanks for the suggestion.
Frigidaire... | Answered on Nov 11, 2015
Check your circuit breakers in the power panel for a bad breaker. The breaker has a pin connecting both handles One breaker can trip without tripping the other. This condition will only allow 115 volts to operate the controls and light bulbs but will not power the heating elements.
Frigidaire... | Answered on Jul 15, 2015
clock, timer, temp gauges for oven shorted out, is there a reset button?
Frigidaire... | Answered on Feb 22, 2015
Not sure what f-15 is either?  Look on the back of the stove and see if there is a tech sheet.  This will tell you the codes.  My guess would be the lock motor has gone bad.  You can check the motor by removing the wires from its terminals and check for resistance with an ohm meter.  Make sure to unplug stove first!  Was this after running a clean cycle?  Let me know what you find.
Frigidaire... | Answered on Oct 14, 2014
Hi Friend, this is Z. Thank you for your inquiry!
Based on the symptoms you are describing, you may either have a communication error from the main control board or a potential wiring failure. You may try and reset your range by disconnecting the to your range for up to ten minutes by flipping the circuit breaker off and back on. If the issue proceeds, then it really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason.
Frigidaire... | Answered on Jul 18, 2014
Good Afternoon Paige, thank you for your post!
Based on what you have described, it sounds like you either have a wiring failure or your burner is faulty. In this regard, it is best to contact a professional to proceed further. Best regard! - Z
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you would like to know the price of the circuit board of your oven. Can you elaborate prior to your problem any other symptoms? For instance, did notice any error codes, or other strange functions? Also, may I have your model number please? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. With this information I can assist you better in pinpointing the problem before you take this step?
Frigidaire... | Answered on Jul 17, 2014
Frigidaire FEF336BC Electric Kitchen Range Logo
510 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
frigidaire cfef372bc2 oven stopped
  • Kitchen Ranges
