20 Most Recent
Frigidaire FEF366DC Electric Kitchen Range Questions & Answers
OVEN CONTROLS AND OVEN DONT WORK. RANGE TOP WORKS FINE.
Hello,We're having the same problem. Oven light works, but plug by oven light switch does not. I changed the screw in fuse (15 Amp) in the oven, although it was blown, it didn't fix the problem.I will be checking the double breaker on the electric panel tonight, making sure it's getting the full 220v, and if that is good, I will be looking at checking and replacing the clock.Hope this helps.
How do you replace a burner switch on a Frigedaire Glasstop Stove
The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
Thanks Again,
Bill
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Error message F!0 displayed
F0
Electronic oven control failure
Replace electronic oven control (also called EOC or clock).
F1
I have a 4 year
I advice you follow the link below to see information therein
http://www.repairclinic.com/Range-Stove-Oven-Troubleshooting#Theclockstopped_electric
Type the above link to see information on how to go about it.
Take care.
Burner will not turn off
You'll need to replace the burner switch. This happens when the contacts become fused together.
